586,149 active members*
3,652 visitors online*
    Nov 2006
    17
    Fanuc OM ATC parameter problem
    My ATC is not working and holding up the machine from running. Is there a parameter setting that allows me to bypass the ATC by telling the PMC that there is no ATC attached to the machine? I can change tools by hand for now until I get it fixed.
    Aug 2011
    2517
    there is an ATC parameter in the PMC to tell it there is no ATC but to know what it is you will need the *machine-specific* manual listing the PMC parameters for your machine. If you tell us the machine type/model maybe someone out there has the same machine and could look in their manuals
    Nov 2007
    188
    tool changer
    I would think it would be a keep relay your looking for not a parameter just guessing.
    Aug 2011
    2517
    they *are* the PMC parameters. There's C, G, K, H and others. Accessed via System/PMC. All those settings are machine-specific and not listed in any Fanuc manuals.
    Mar 2005
    816
    Whats wrong with the ATC?
    Tell us more about your machine.
    Yeah, it could be a Keep Relay.
    But yeah, the PMC parameters are mostly "Machine Specific" so you have to find them from a machine like yours, but sometimes they require a little fine tuning.
  1. fanuc 6t parameter problem
    By moghul in forum Fanuc
    Last Post: 12-30-2011, 07:59 PM
  2. hitachi seiki parameter problem
    By kurt_laughton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2011, 06:31 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Machine parameter problem ...
    By talash in forum DNC Problems and Solutions
    Last Post: 10-09-2008, 10:20 AM
  5. Miyano parameter Problem
    By AFX in forum Fanuc
    Last Post: 02-01-2007, 08:28 AM
