586,753 active members*
7,208 visitors online*
Results 1 to 8 of 8
Threaded View
    Jun 2011
    13
    Question Galil DMC-2143 - Red LED
    Hi everyone!
    I mistakenly applied 10.7V to the pin 63 (Reset) instead of sinking it to 0 (zero) volt, for a split second. Now the red LED is ON all the time and I can no longer communicate with the board. However it still has the same voltage reading that it used to have on all the 96 pins, except the X, Y, Z & W Amp Enable. Which makes sense: If there is a fault, all the axes should be disabled...
    The reset pin goes straight to the IC U35 (see attached picture). Could anybody help me find this IC? It is smaller than a grain of rice and appears to be made by Texas Instruments. Since I overpower it, I will replace it first and go from there!
    Any help will be greatly appreciated!
    Luiz
  1. Galil Servo Design Kit / Galil Suite
    By Neo20X in forum Controller Cards
    Last Post: 03-12-2013, 11:31 PM
  2. Who PM'd for Galil VBX
    By Al_The_Man in forum Controller Cards
    Last Post: 05-01-2010, 04:58 PM
  3. other than Galil
    By bobk in forum CamSoft Products
    Last Post: 12-30-2009, 11:39 PM
  4. Galil Anyone
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 10-29-2006, 08:52 PM
  5. Sure Servo to Galil
    By Mountain in forum CamSoft Products
    Last Post: 07-05-2006, 06:40 PM
