586,594 active members*
3,002 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas EC-500 Pallet allignment
    Mar 2008
    Our shop just got in a used EC-500 Horizontal mill a few months ago. We are pretty undermanned right now and so I have had trouble finding time to get started on this machine, as I have had to make a tombstone for it. So yesterday I fire up the machine and start to mount up the tombstone and as I am trying to indicate it in I notice that the Pallets are both WAY out of alignment. So much that I cant even get the tombstone indicated in.
    The Pallet has a 1 Degree indexer... But 1 degree moves far more than I need it to in order to indicate the tombstone in. Any way, is there a procedure for adjusting the pallets home point?
    Dec 2009
    75
    THScout,
    Did you get your problem solved? I cannot help. Was just browsing the Haas forum for Haas horizontal info. I am considering an EC 630 or something comparable. We only have vertical experiance but are looking at product that I think will be suited to a horizontal. Just looking for general info.
    Murphdog
  1. vf3 ss pallet changer
    By mayhem in forum Haas Mills
    Last Post: 04-25-2011, 10:45 PM
  2. HAAS Pallet changer alarm
    By horst007 in forum Haas Mills
    Last Post: 02-18-2011, 04:04 PM
  3. HAAS HS-1 Pallet Change problems
    By cweiss in forum Haas Mills
    Last Post: 07-30-2008, 10:42 AM
  4. Hmc Pallet ?
    By Rcky123 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-27-2007, 06:36 AM
  5. Lathe allignment HELP
    By Jedi in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2006, 01:22 AM
