586,761 active members*
7,486 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > still more Vertical Lathe fun -- G96 CSS mode
    Apr 2006
    439
    I was messing around with the vertical lathe setup this weekend and found that it can do G96 (CSS) constant surface speed. I had read in the mach forums that it was bugy and wanted to see. it turns out that it only has a problem in FPR feed mode ( G95 feed per rev ) but it seems to work fine in FPM ( G94 feed per minute ) mode. I am not really sure how much I would use this but " I had to know"
    The code for this cut is..
    G20 G40 (inch and clear any comp.)
    G00 X1.635 Z-0.02 (rapid to start point)
    G48 S4000 (set max spindle speed)
    G96 S300 M3 (select CSS and sfm and start spindle)
    G94 (set to feed/min)
    G01 X-.05 F3 (feed to X... @f3)
    g0 z.1 (retract to safe Z)
    x2.1 (retract to clear work )
    G97 S0 M3 (set to rpm mode)
    M30 (all done)
    The G48 sets a max allowable rpm ( I wasn't sure how fast I could spin that R8 chuck)
    Not sure how much I will use this...but I thought it was cool.
    Listen to the spindle ramp up as the diameter gets smaller.
    [ame=http://www.youtube.com/watch?v=DllPNbqfnvY]G96 test on Tormach vertical lathe - YouTube[/ame]
    Scott
    www.sdmfabricating.com
    Aug 2009
    986
    Scott,
    Would you be willing to share your Mach config file with me? I'd like to try this out, and don't want to have to reinvent the wheel.
    Frederic
    Apr 2006
    439
    I would have to check with Tormach. I think you will need to sign the waiver to use it.
    Scott
    Aug 2009
    986
    OK. I can sign the waiver if need be. I didn't realize it was a Tormach file. I thought it was one that you had developed on your own.
    Frederic
    Apr 2006
    439
    Hi Fred
    I did do the file. But in order to use it you have to have the unlocked version of Mach. Otherwise you cannot select that configuration at startup. I cloned the base config and renamed it Vertical Lathe .
    I will talk to Tormach tomorrow.
    Scott
    Jul 2009
    147
    "Would you be willing to share your Mach config file with me? I'd like to try this out, and don't want to have to reinvent the wheel."
    +1
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. My Tormach Vertical Lathe
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-05-2012, 04:17 PM
  3. version 22 verify not working in lathe mode
    By conceptmachine in forum BobCad-Cam
    Last Post: 08-29-2008, 01:54 PM
  4. HAAS LATHE Graphics Simulation MODE
    By DEAN in forum Haas Lathes
    Last Post: 11-19-2007, 04:45 AM
  5. CNC Vertical Turning Lathe
    By Harshwardhan in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2007, 05:58 PM
