I finally got my router up and running. Everything is working and I have run a few toolpaths to test it out. My question is about the charge pump. I'm using a Gecko 540 controller. As long as I leave the charge pump off everything works fine. When I try to turn on the charge pump I can't get the e-stop to clear from Mach 3. I have the charge pump setup on pin 16 in the mach 3 software. My understaing is that as long as you power up your PC before you put power to the machine the charge pump is not needed. Is that correct?
Brad
