586,535 active members*
2,800 visitors online*
    Mar 2011
    19
    Constant Force Springs
    Has anyone tried to use a constant force or "clock" spring for a counterweight?
    I was thinking about something like this:
    https://www.vulcanspring.com/
    It seems like you could come up with a pretty good system with a longer life and a more constant lift than a gas spring.
    Dec 2004
    95
    Quote Originally Posted by rrobb View Post
    I'm guessing that one of the biggest issues with gas springs stems from the use of GSs with the incorrect rated force. The rule of thumb seems to be matching the weight to be countered with the rated force of the GS. Big mistake depending on the GS.
    When looking for a GS for a X2 mini-mill, I followed advice/suggestions in this thread;
    http://www.cnczone.com/forums/bencht...s_springs.html
    Went and ordered a spring rated at 40 LBS. It proved to be totally unsuitable after installing. Pressing down on a bathroom scale with the 40 LBS GS could not produce any movement until the scale read a whopping 54 LBS. Based on that, I then ordered one rated at 20 LBS. The scale read 32 LBS when doing the same with the 20 LBS GS and it worked perfectly after installation. I could move the head to any position and it remained motionless. Also, the effort required to move the head felt the same in either direction at any location.
    I converted the mill to CNC and that GS allows me to reach 250 IPM rapids on the Z-axis in either direction. Here's a shot of it;
    Gas spring (4) photo - Eldata photos at pbase.com
    Dec 2006
    839
    You know now that you meansion it a garage door spring would work quit nice. There even ajustable.
    Jess
    GOD Bless, and prayers for all.
  1. X2 Gas Springs
    By Tallen in forum Benchtop Machines
    Last Post: 09-23-2009, 10:34 AM
  2. valve springs
    By Hiredgun in forum I.C. Engines
    Last Post: 10-14-2008, 10:39 AM
  3. Springs
    By CNCMike in forum Solidworks
    Last Post: 03-20-2007, 05:25 PM
  4. Constant Force Spring for Counter Balance
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 10-25-2006, 03:10 PM
  5. How to make a Constant Force Spring
    By jwvica01 in forum Benchtop Machines
    Last Post: 06-28-2005, 01:17 AM
