586,912 active members*
2,912 visitors online*
Results 1 to 3 of 3
    Sep 2011
    Question Cheap materials for laser cutting
    I've been working on making these things(MAKE | Laser-Cut Polygonal Sculptures), using acrylic from a local supplier.
    I'd like to make a few more, with the aim of producing wearable pieces instead of heavy stationary pieces.
    To that end I've been thinking about using cardboard or thick card stock for the large panels. It would be cheaper, lighter, and most importantly, would not shatter if dropped. My problem now is that I don't know where to find sheets of card stock in large sizes (~17x23 in)
    If there is a plastic that can be laser cut that is also slightly flexible and light that would be even better. This isn't very precise, but the semi-rigid, slightly transparent plastic used to cover binders would be perfect.
    Any help would be greatly appreciated.
    Sep 2011
    I just found out about Coroplast, and that looks useful. Anyone have any experience with it?
    Oct 2010
    I have cut basic designs out of coroplast, such as arrows or cut out designs. It cuts nicely, but you need a knife to finish the separation. The veins in coroplast won't burn off as quick as the front and back piece. I just take a razor and run it in the cut out hole and cut through the veins, it works well and very quickly.
  1. Where do you get materials... cheap?
    By Sporqster in forum MetalWork Discussion
    Last Post: 02-17-2023, 10:21 AM
  2. May we know your experience of Materials, Cutting Depth which Laser tube could do
    By echojdlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-25-2011, 02:51 AM
  3. Tips on laser cutting soft materials
    By drmitsos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-12-2010, 06:52 AM
  4. Cutting XPS foam with cheap laser?
    By aleksazr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2010, 03:31 PM
  5. laser cutting tough, light, flexible sheet materials?
    By vacpress in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2008, 02:36 AM
