586,537 active members*
2,878 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > problem with VFS 5 Milacron Arrow 750 with CNC Acramatic 2100
    Sep 2011
    Unhappy problem with VFS 5 Milacron Arrow 750 with CNC Acramatic 2100
    Hello kollegs.
    I need advice. During working spindle the machine surprisely stopping, spindle rotate on inertia any time, axis Z fails down 2-3 mm, and we have alarms (39-41 "axis "signal ready" missing;39-29 "Spindle not up to speed"; 39-31 "Spindle stop failure" ) In this time the loading of spindle is 85% and more till end! But spindle is not under load and no jamming.
    Drives Kollmorgen BDS-4, VFS -5ill
    Thank you very much
    Sep 2010
    1765
    Sounds like your vfs5 just broke - with shorted output transistor.
    the cnc control faults reported say the vfs5 is off (faulted). this shuts off machine, causing z to shut off and it drops 3mm before brake comes on so no problem there.
    since load meter says 85% load when none, sounds like vfs5 is really broke and maybe has shorted output transistor causing load meter to go to 85% when it turns on.
    contact Cincinnati - they will repair this for you: they have Russian language listed on their website i see - link & phone number:
    http://www.mag-ias.com/en/part-store.html
    http://www.mag-ias.com/ru/mag/stando...obrabotka.html
    Sep 2011
    Thank you very much for answer. I have one more question about ARROW 500. After loading of ACRAMATIC 2100 we have not on the screen coordinates of the machine (X,Y,Z...) and their values. No errors occurs during and after loading.
    Sep 2010
    1765
    i cannot help on cnc, jut servos and spindle. again, contact Mag. I believe they have service people in Russia.
  1. CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    By CHANDRU in forum Cincinnati CNC
    Last Post: 03-03-2015, 08:35 PM
  2. Cincinnati Milacron Acramatic 2100 Power Supply Failure error
    By Wurmwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-17-2012, 07:53 PM
  3. Arrow 1000 W/Acramatic 2100 - PC crashing
    By Heinster in forum Cincinnati CNC
    Last Post: 02-11-2011, 10:57 PM
  4. Arrow 500 - Acramatic 2100 No Power to Controller
    By hodge_thomas in forum Cincinnati CNC
    Last Post: 05-10-2010, 01:36 PM
  5. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
