586,929 active members*
2,839 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Coupling stepper motor to ball screw
Hybrid View
    May 2011
    Hello all, I come again in my time of need.
    I've recently came by some ball screws for my homebrew CNC mill but the output shafts on my stepper motors are much smaller than the ball screw shafts and the shafts on my stepper motors are geared. Does anybody know a coupling solution for mismatched shaft sizes? I know I could just drive the screws with belts, but I would prefer to couple my motors directly to the scerw shafts. Also, does anybody know a good way to remove the gears from my motor shafts?
    Nov 2009
    4415
    Look up "Oldham Couplers". They are a 3 piece zero backlash coupler. you buy one half for the stepper the other half for the screw or whatever you are trying to join.
    Jan 2010
    2141
    It might be helpful if you could post some photographs of the stepper shaft with attached gears.
    BTW, what are the shaft diameters that you are working with (for both the ballscrews and stepper motors)?
    Nov 2009
    4415
    Jun 2011
    152
    Without more exact information on the sizes of your ball shaft ends and the stepper motors it's hard to give you good advise. In general, gear reduction heads on stepper motors are typicaly removable, however the gear on the motor shaft may be pressed on,...try pulling it off or cut it off using a dremal cut-off wheel if needed.
    For the shaft coupler, you might want to look into "Flexible shaft couplers", you can find them on e-bay for only a few dollars each (shipped from china). They come in many standard shaft sizes and hold up very well for most stepper motor applications.
    Cheers
  1. FIX: motor shaft and drive screw alignment, coupling
    By fivefishcnc in forum DIY CNC Router Table Machines
    Last Post: 02-09-2009, 10:30 PM
  2. Ball screw and Stepper Motor Size
    By ericdwilso in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 08:40 PM
  3. Coupling stepper to ball screw
    By garagefela in forum Linear and Rotary Motion
    Last Post: 08-18-2006, 11:51 PM
  4. Can we help Ito (Stepper screw coupling issues)
    By ynneb in forum Linear and Rotary Motion
    Last Post: 11-25-2005, 06:31 PM
  5. coupling motor to lead screw ideas?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2003, 05:18 PM
