587,051 active members*
3,581 visitors online*
Results 1 to 9 of 9
    Aug 2011
    Nomura Swiss NN-13SB (Advice?)
    I'm looking into buying three 1999 13mm machines for making three relatively simple small parts. We aren't going to be breaking down these machines very often to change setups and what not. What do you guys suggest as far as reliability on running these machines? Gosiger seems willing to service these machines for us. We are getting a great deal on these price wise, so I want to know if it's worth the risk or should we pay a higher price for newer machines.
    Any input will be helpful guys, thanks!
    Feb 2011
    what are you considering to a "great deal" on these? Price?
    Aug 2011
    Three identical machines with three identical magazine bar feeders, installed for $45,000.
    The machines are currently running production parts. And there will be some kind of inspection done. I was more worried about the Nomura brand and reputation for reliability. We have good support lined up for the machines. What about the actual machines themselves? Good experience/Bad experience? More failure rates compared to other brands of swiss?
    May 2011
    What kind of coolant are you planning on running? We exclusively run Stainless and Titanium and run oil in our machines and in the 3 years that we had our nomura's I had to replace guide bushing belts too numerous to count and ultimately had to have custom belts made. I also had to replace two power supply cards, a sub-spindle encoder, and two spindle driver cards. IMO Nomuras are put together like IKEA furniture. They work for simple things, but are not very durable. I should, however, say that I am spoiled and biased due to trading our nomuas in for Citizens. After running a citizen for a week, the nomuras just felt like toys.
    Aug 2011
    It would be strictly stainless steel with oil coolant. I kind of got that feeling, but if we are only running the lights out of 1 part on a machine, do you think we will have the same problems?
    May 2011
    Your mileage may vary. We had 2 nomuras. An NN20UB and an NN16BIII and aside from the guide bushing belts, we also replaced a few main, and sub-spindle belts and well as Y axis drive belts. I do know people that are quite happy with theirs and at that price, it would be hard to pass. You should be comfortable digging in to these machines and shouldn't be shy about taking covers off and troubleshooting problems yourself.
    Aug 2011
    I appreciate you giving your opinion on this. We are pretty good at doing our own trouble shooting, but I just don't want to have to worry about shutting down production runs because parts keep leaving tolerance. We are trying to hold .001-.0005 type tolerances on some parts. Albeit the parts are extremely simple.
    Out of curiosity, how much was it to fix those belt problems?
    Mar 2008
    443
    Nomura has changed distribution (and therefore, support) in the USA more times than I changed my socks. They have a decent machine, but if you need help you are then chasing around a lot. If Gosinger has promised support, hold them to it: Put it in writing.
    Feb 2016
    Re: Nomura Swiss NN-13SB (Advice?)
    I have over 25 years experience with the Nomura line of Swiss machines and they are a pretty solid machine. Like any other Swiss machines, belts, spindles and guide bushings wear but for quick setup and accuracy, I would put them up against any of their competition. I trained the Gosiger people in the programming and operation of the machines as well as took them to Japan for factory training in the maintenance of the machines so you should be good as far as service. Chris Moore knows his way around the machines. The is one Nomura customer that has over 150 Nomura machines that have been on line for close to 20 years with the normal repairs and up grades due to time in service and the 24/7 operations.
  1. Any Nomura Info
    By JMS4287 in forum CNC Swiss Screw Machines
    Last Post: 11-04-2013, 08:42 AM
  2. Replies: 2
    Last Post: 10-08-2010, 04:45 AM
  3. advice on new swiss purchase?
    By panaceabea in forum CNC Swiss Screw Machines
    Last Post: 01-12-2010, 02:49 AM
  4. Swiss Macros and Tips, and advice.
    By SWISS20 in forum CNC Swiss Screw Machines
    Last Post: 02-01-2008, 08:54 PM
