Ok, I'm in the process of installing a servo 3 axis cnc kit on my mill / drill, which I originally thought it had 16tpi lead screws, but ends up being 10 Tpi screws. What is the formula to gonkculate the rpm speed / threads per inch to figure out what the IPM rate would be?
I planned on going direct drive, Does anyone see me having an issue in doing so ? Should I go more towards a timing belt reduction setup?
I'm working primarily with Aluminum, and looking for accuracy than ipm feedrate world records.
Art
