After more than a year of lurking, I'm now in a position where I need to buckle down and get my first machine built. Maybe I've over-researched, and have made things out to be more complicated than they need to be.
The objective : build a 3-axis (add 4th later) machine with good enough accuracy and resolution for a small production shop to plow through MDF and acrylic, with perhaps some occasional aluminum sheet thrown on. ON A BUDGET. I'd really like to have a ShopBot PRS Alpha, but was hoping to a machine with that capability for less money.
Basics:
- 48"x96"x12" work envelope
- 3kw chinese H20-cooled spindle
- welded steel frame sides, bolted crossrails. I'll use some of Madvac's epoxy-bedding approach.
- ~100# gantry
- I've no idea WHY, but I set an arbitrary goal of 1000/min rapids and who-knows-what cutting speeds.
- probably headed toward Keling's 906oz-in steppers. Slaved dual-X. Can't decide between R&P and belt drive, but that's another thread.
I've got some mechanical background (engineer, certified welder) just never done much machine design. I normally lean toward extreme overbuilds, but I'm trying to keep myself grounded and focused on the goal at hand : build a machine appropriate for a woodshop, not for NASA. Budget is the primary constraint, followed closely by ease of construction.
So, my basic question here is, I looked into Bishop Wisecarver Dual-Vee, HiWin/THK profile Rails, and Pacific Bearing's IVT rails. Trolled E-bay a lot, and haven't pulled the trigger on anything yet. Anyone able to share thoughts on which direction to head?
Many thanks in advance. I know there's a TON of knowledge here, and looking forward to what folks will share.
