My KL34H280-55-4A motor came with green, white, red, yellow wires but spec sheet has black, green, red, blue. I Want to wire bipolar series. Anyone wire up one of these?
found this one. I know It's not your but does show white wire. Maybe wrong motor....?
Your motor has four wires, so there is no concept of "bipolar series" with that motor, rather you would just be wiring it for "bipolar" connection.
Do you have a multimeter? You should be able to do a quick resistance test to see which wire is connected electrically with which other wire, in order to identify the two different windings.
