Hi All,
what is everyone using for lubrication?
Do you use something different on the ball screws as opposed to the ways for example.
Has anyone heard of Du-Ponts Teflon Multi-Use Lubricant, which sets up dry?
Thanks for all responses,
Phil
Hi All,
Phil
THe things i lubricate most regularly:
Ways - Motor oil works very well, it seems to stick to the metal and lasts.
Leadscrew- I use a mixture of white lithium and motor oil, not too much grease or else it just makes a pile
Phil,
I use way oil on the ways and spindle oil on the ball screws. Both are available in 1 gallon containers from McMasterr Carr. I stick with the Mobil brand name ones even though the "no-name" ones probably come from the same refinery. I do not care for the teflon multi-use lube.
Ken
KDN Tool
I strongly discourage the use of motor oil for the ways. It sticks and it works, yes but if you are doing fine moves you can feel a difference when using way lube. Use way lube - there is a difference. Mobile Vactra #2.
On the ballscrew - a light lithium grease works well. The only time I would recommend an oil is if it is oiled regularly and tied into an automatic lubricator. If it is lubricated occasionally through a fitting, then use a light bodied lithium based grease.
If it is a high precision or small diameter ballscrew, NSK Precision America recommends an ISO Grade 32 through Grade 100 (approx. SAE15 through SAE30) for oil lubrication or a lithium based grease with a viscosity of 30-140 cst at 40C (very thin bodied grease).
I would stay away from using a grease with Teflon or other additives for a precision, recirculating ball nut.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Thanks for all the responses everyone.
Phil
Any Idea where one can locate Mobile Vactra #2 in Toronto, Canada?
thanks
