here is a "rebuild" of my lathe with an improved turret design
friends,
i have rebuild my lathe. The lm guides, balscrews, motors and vfd is the same. All is mounted on a newly casted iron bed , a new headstock and new bearings and a new enclosure with external controls for feed hold, spindle, cyclestart, coolant and estop. There are two mpg one each for x and z of my lathe. One switch for jog toggle and a homemade joystick for fast jogging.
The new thing in this lathe is its toolchanger. completely electric deisgn. a 200watt reversible motor, a worm gear, 8 photodiodes an atmega16 is used to drive it. The best thing about the toolchanger is that it locks the toolplate with the turret base using a screw and nut so there is absolutely no deflection on the tool what so ever load is due to heavy cuts. Watch the video and pics and you will get it.
[ame=http://www.youtube.com/watch?v=0b3ImCmnPPQ]100_6802.flv - YouTube[/ame]
jasminder singh
It is better to die for something than to live for nothing.
