I searched and found some helpful info on these motors including specs below, but still not sure which wiring diagram I should be following. I think the last is bipolar.
I have two 48V/4.2 amp Power packs. One for Y,Z axis and 1 for the X axis's.
The last diagram shows the motors amp at 2.8, will one of these power packs be enough to run 2 of these motors?
Here is a link to the drives I will be using
Stepper Motor/Stepper Gearmotor/Stepper Motor Driver wholesaler and supplier
Thanks in advance,
Dan
