586,847 active members*
2,450 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3D surface toolpath help
    Apr 2011
    Could anyone help me out with a few Milling questions I have?
    I tried using a Rough Surface Pocket toolpath today and was unsuccessful because the toolpath would not reach the floor. The stock to keep on the drive surface was set at 0. The toolpath appeared to finish the walls the way I wanted but left unwanted stock on the floor. Any ideas?
    Second, what is the best approach for tappering a 3/8" wide by 3/16" depth conical slot? The finished slot would appear as like a half cone layed on its side. I used a Contour toolpath with a 3/8 Ball endmill to rough followed by a Surface Finish Contour toolpath with a 3/32 ball end mill with acceptable results. It worked alright but the floor wasn't smooth even with a .002" stepover.
    Lastly, I wasted alot of time today redrawing edge entities that were to be used for chain creating. Without the redrawn entities chains would not branch, instead would create individual chains. I decreased the chain tolerance in the options dialoge box, which didn't fix it. I'm working with a parasolid file.
    Thanks for any help!
    Jun 2009
    65
    When working with imported solids always try to Create Curves on all edges so that you can have some Geo to chain to.
    Aug 2011
    could you paste a image and together with the problem, and let me see if i can help you.
    i also suggest you to use an end mill for rough mill, it will works more efficiency.
    how do u thk?
    Dec 2008
    3115
    Quote Originally Posted by david martin View Post
    This is OK for roughing
    Try the Surface Finish Flowline for the finish passes, cusp height of about 0.0005 - 0.0010" ( it'll work the step over in relation to the surfaces being cut - you will have to select the cutting direction & starting point )
    Try using the Create, curves from solid, ( you should have had wireframe entities when importing,.....you could have multiple copies ( this also stops chaining )....try the Delete Duplicates
  1. Blend Surface Toolpath
    By lavrgs in forum Mastercam
    Last Post: 12-01-2010, 05:10 PM
  2. Curved Surface Toolpath
    By ehsanmax in forum Mastercam
    Last Post: 03-14-2008, 12:39 AM
  3. Help with surface toolpath.
    By M-man in forum Mastercam
    Last Post: 04-12-2007, 09:02 PM
  4. Surface toolpath
    By Julian M in forum Mastercam
    Last Post: 01-14-2007, 01:30 PM
  5. surface toolpath
    Last Post: 01-06-2007, 12:53 AM
