For the Haas TM-2, is it possible to "edit" the visual quick code. Another words, when we edit the numbers in the quick visual program, they visually change, but when we run the program, it does run with that edited change. Thanks.
If you change anything within the VQC template (O9997), then the output G-code generated by VQC will be changed. Just so you know, the VQC program reads the template and uses that information to generate the G-code. I hope this helps.
