586,704 active members*
2,495 visitors online*
    May 2008
    15
    Doosan Puma Programming
    Hi guys, i currently run a Doosan Puma CNC lathe with Fanuc controller.
    I can program with fanuc that isn't a problem, i want to know if i can get away with using the old school canned cycles instead of this G1148 (dunno if this is a code) bull****. I'm used to the g71, G72, G70 ect codes.
    Any help pls would be appreciated!
    Cheers!
    Aug 2009
    684
    You should still be able to use the old cycles as well as the manual guide i cycles, but do try to persevere with the new format, once the logic behind them becomes apparent you will like them, and maybe, someday, even learn to love them.....(group)
    DP
  1. Replies: 7
    Last Post: 11-04-2019, 02:20 AM
  2. Doosan Puma 800 EZ-Guide Prob
    By CNC TECH in forum Fanuc
    Last Post: 07-07-2010, 07:49 AM
  3. Need basics on operating doosan puma 400
    By tkokenos in forum Daewoo/Doosan
    Last Post: 03-24-2010, 05:30 AM
  4. doosan puma 400L quetion
    By ming035 in forum Daewoo/Doosan
    Last Post: 11-18-2009, 06:23 PM
  5. Doosan Puma MX3000S
    By broncranger in forum Daewoo/Doosan
    Last Post: 04-15-2009, 06:51 AM
