I have not had to use this before so please excuse my ignorance of this feature. I am milling some pockets for bearings to sit in, so want a good fit. I have been using a 10mm slot drill to open out a 28mm pocket, which has come out undersize. My cam system has created offset geometery so now I want to use the tool wear feature of the control to open out the pocket to a good fit. I take it the best way is to use a G41 command and enter something in the tool diameter coloum of the offsets page. Question is what do I enter for this, is it the difference between my measured pocket and the finished size, and if so is a positive or negative value.
Any help would be appreciated
