Originally Posted by
eliot15
Thanks cadman,
Thats encouraging. It means that the settings I opted for in Program_2 actually did produce the correct behavior.
So is this right...If I don't create part stock, GibbsCAM uses the work envelope defined in the Document Control (x, y, z extents) as "default stock".
If I create a seperate workgroup and define my part stock in that workgroup, this new stock overrides the default work envelope stock.
Then GibbsCAM alters its tool path to map more closely to the custom stock?
