586,432 active members*
4,123 visitors online*
    Jun 2007
    7
    Question Right Hand Left Hand thread ????
    Ok here goes,
    Can anyone tell me what is the difference between a left hand and right hand thread tap?
    All I know is, if the thread on a bar is angled upwards to the right as you are looking at it, it’s a right hand thread, and left if it is angled upwards to the left.
    Does it matter which (right or left tap) I buy, to make my own drive nuts.
    I just can’t get my head around this.( if I tap a round bar say 40mm long and tap it with either hand tap, it shouldn’t matter , I just turn the nut round ??
    The reason I am asking this is because I want to make my own anti backlash drive nuts out of derlin using trapizidol (12 x 3) lead screw, which I already have.
    And if anyone can give me a few pointers on how to make these nuts I would be really grateful.
    Sorry for sounding a bit thick, but hope you can help.
    Turning it around doesn't change it from RH to LH. You need a RH tap for a RH screw, and a LH tap for a LH screw.
    Chances are about 99.9%, that you have a RH screw. RH means if you turn it clockwise into a nut, it'll go into the nut.
    Aug 2009
    22
    right hand threads tighten clockwise, left hand tighten counter clockwise.
    Jun 2007
    7
    Thanks for the info fellas. Just ordered a right hand tap so im going to have a go at making my first nut !!!! anyone know what is the correct size drill bit for a 12mm be 3mm pitch, trapizidol tap ??
    Aug 2009
    22
    good rule of thumb with metric is diameter minus pitch = tap drill size. 12-3=9mm
    Mar 2008
    240
  1. left hand 3-48?
    By skmetal7 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-05-2009, 07:49 AM
  2. TL-2 Left Hand Thread Routine
    By dhelms in forum Haas Mills
    Last Post: 12-24-2007, 07:36 AM
  3. Why do you use your left hand
    By ImanCarrot in forum MetalWork Discussion
    Last Post: 10-15-2007, 12:14 PM
  4. Left hand thread with rigid tap
    By Vern Smith in forum Haas Mills
    Last Post: 10-01-2007, 02:15 AM
  5. coverting from Right-hand to left-hand coordinate system
    By eltonr in forum Uncategorised CAM Discussion
    Last Post: 10-15-2004, 02:40 AM
