Up front, I am a MTB first and a machinist or sorts second.
IMO, The need you are going to run into to in machine square blocks of aluminum and copper is Rigidity, as well as cooling already mentioned.
Many of the gantry's you will find here have high RPM spindles and are built for wood and thin sheet metal material that require no cooling.
Any machine where the lateral forces on the tool are high requires a great deal of rigidity in the construction of the gantry.
I would have though a small Knee mill such as BP or XLO would have been a good choice for the blocks.
The thin panel material could be done on a solid quality router gantry?
I think one machine to do all will be a compromise.
Al.
