586,647 active members*
2,059 visitors online*
Results 1 to 7 of 7
    Poor cut quality
    I am running a plasmacam with a TD52 with shielded consumables. I have tried every amp setting and cut speed and this the best I could get 16g to cut.
    75 ipm
    Cut Height .187
    40 Amps & 40a tip
    Also there was enough heat I guess it caused the letter M to melt some.
    Is expecting better results than this unrealistic?
    May 2008
    Lower your cut hieght to about .060 and increase your speed to about 150ipm the increased speed will decrease the dross on the bottom of the plate. Also check your consumables for wear. Just my opinion as i am a rookie at this
    Jun 2007
    50
    Cut quality
    What model Plasmacam and which software version are you using?
    George
    Got it cutting better now. Lowered my cut height.
    I'm running a DH2 and Design Edge.
    Jun 2007
    50
    The typical cut height for a TD torch is .07 and the Arc Voltage Shift will be .750
    George
    Mar 2011
    i run at 175 ipm on 16 gauge and it works out great
    Jun 2011
    GOOD ADVICE
    Dear Steve
    the best is just take it cool & easy and do it by your self.
    its a game between you and the machine.
  1. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  2. BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar)
    By zerodegreec in forum Benchtop Machines
    Last Post: 09-14-2010, 09:01 AM
  3. 3/16 Aluminum - POOR CUT QUALITY
    By zeoncomp in forum Waterjet General Topics
    Last Post: 08-01-2010, 05:10 PM
  4. Poor quality and Wavy Plasma cuts (Pictures)
    By Normsthename in forum Waterjet General Topics
    Last Post: 05-11-2008, 03:35 PM
  5. tri-power poor quality
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 12-02-2007, 01:45 AM
