586,964 active members*
2,295 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Okuma Multus B300W Post Needed
Hybrid View
    Jun 2006
    59
    I need a post for a Okuma Multus B300W as soon as possible. Can anybody help me out?
    Apr 2006
    822
    Would a lump of 4x2 work? Or are you after something a little more specific?
    i.e. what software are you using? That part is kinda important you know!
    haha just realised that you posted this in the mastercam forum so I am guessing you are using some version of Mastercam then?
    Dec 2008
    3120
    Quote Originally Posted by broby View Post
    We'll use the 4X2 on both of you. (chair)
    but, Brian is right, you haven't given what Mastecam version you are using.
    Have you asked your reseller for his recommendations of what is available "off the shelf" ? there is a 4 axis Okuma lathe post available.
    He should be setting your machines up as part of the "sale" or maintenance
    -plus any minor customising to your normal shop practices,
    -plus a little guidance training in it's use.
    Jun 2006
    59
    I'm using X5 and tweaked some things but I'm not sure how to get it to call up the tools and tool offsets the way I need.
    Here is a sample.
    NT10 (Before tool change line number used for restarts)
    MT=01001 (Calls up tool. MT=(### tool number)(## station number – which will always be 01 for us because we only have 1 turret)
    M321 (tool change)
    NAT10 (After tool change line number used for restarts)
    G141
    G50 S2500
    G97 S500 M3 M42 M08
    TL=01010010 M602 BT=0 (Tool Offset call, TL=(## tool index position 1-12)(### tool number)(### offset number)(M602 is tool index clamp position +0degrees)(M603 is tool index clamp position +180degrees)(BT=0 is head position at 0degrees, BT=1 equals 90degrees, BT=2 equals 180degrees)
    G96 S350
    .........Program.......
  1. Multus B300W fiasco
    By mstlouis in forum Okuma
    Last Post: 06-29-2019, 10:28 AM
  2. Replies: 6
    Last Post: 02-10-2011, 07:06 AM
  3. Feature cam and Okuma Multus
    By garnetram in forum FeatureCAM CAD/CAM
    Last Post: 02-22-2010, 03:16 PM
  4. Best cam for multitasking Okuma B300W
    By 3dman in forum Uncategorised CAM Discussion
    Last Post: 09-16-2008, 07:35 PM
  5. just ordered an okuma multus
    By cncclimber in forum Okuma
    Last Post: 05-13-2008, 08:02 PM
