586,551 active members*
3,246 visitors online*
    Mar 2010
    Exclamation Problem with Spindle.
    Hi friends,
    im arul from india.
    im a regular reader of this site/
    im having a problem with our CNC Wood working machine, which we got directly from CHina, 1.5yrs ago. its a 2 spindle machine, but single cantry.
    Both spindles can do same work at the same time, makes it like a COPY machine.
    the problem is, with both spindles now.
    1. One spindle doesnt move left / right ( x axis ), it gets like STUCK, then i see a RED LED on the X Controller inside the COntrol Box. But it can b moved Manually. Z Works Fine.
    2. Another spindle, no similar problem,. but when i do a job for 10 mm depth with a 6mm Endmill, it goes ok for some place, but DRILLS into the wood, making the collet get stuck into the wood. after i maually cancel the job and move it Z+, it sometimes moves Z-,
    Can u please suggest any idea's to sort out this problem ?
    thank you guys.
    There is no reply from the China People. hope to get reply soon.
    Apr 2009
    163
    no details on the machine your using. how do you expect anyone to help?
    Joes cnc 4x4 sold
    new build in progress cncrp 2448
    Dec 2012
    19
    Red face
    Quote Originally Posted by arulnathan View Post
    Hi friends,
    im arul from india.
    thank you guys.
    Hello, I think it is a long time for your spindle, maybe you can have a inquiry to the factory, or purchase a new one to update.
    About your problem of cnc router, I think you can have a check of the software first
  1. Spindle Problem
    By Ray Machine Inc in forum Videos
    Last Post: 03-12-2010, 10:21 PM
  2. NM-135 spindle problem
    By keithmcelhinney in forum Machines running Mach Software
    Last Post: 06-11-2009, 12:49 AM
  3. NM-135(2.1) spindle problem
    By keithmcelhinney in forum Novakon
    Last Post: 06-10-2009, 09:11 PM
  4. C6 SPINDLE RPM PROBLEM
    By gio1976 in forum Syil Products
    Last Post: 11-07-2008, 09:04 AM
  5. Spindle Problem - Help!
    By bcnc in forum Syil Products
    Last Post: 05-03-2007, 07:49 PM
