586,967 active members*
2,912 visitors online*
Hybrid View
    Feb 2011
    423
    thrust bearing ?
    What type of grease and how much do I need to use in a new set of thrust bearings for a 4020?
    Scott
    Jan 2008
    45
    I just use a good quality, water proof wheel bearing grease.
    Mar 2010
    grease
    Must trust bearings are packed with kluber grease,it is expensive but good high end grease that will last.most new bearings come prepacked with grease already in it.
    Feb 2011
    423
    Thanks guys. Alex I asked this question before unpacking brg's . The last ones I ordered were dry when they arrived, but these were packed.
    Thanks again.
  1. thrust bearing nut wrench
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2010, 01:55 PM
  2. thrust bearing for bk/bf setup?
    By 15mgtar in forum Mechanical Calculations/Engineering Design
    Last Post: 09-13-2009, 09:23 AM
  3. X-Axis Thrust Bearing?
    By TurtleRacing in forum Fadal
    Last Post: 05-22-2009, 12:22 AM
  4. Thrust bearing numbers
    By geebee1912 in forum Fadal
    Last Post: 08-25-2007, 06:43 PM
  5. What do you think of this thrust bearing design?
    By cncadmin in forum Benchtop Machines
    Last Post: 06-03-2004, 02:20 PM
