586,693 active members*
3,002 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How can I create .pdf from X5
    Jul 2007
    72
    We are trying to use X5 but one of the issues we are running up against is how to create .pdf without have to buy more software. Previously we created a .plt file then used Corel to create a .pdf, but it looks like .plt is gone. Any suggesions how to accomplish this...Corel can read .dwg but not the version that X5 creates, we get corrupt file msg. when attempting to open in Corel.
    Any leads suggestions appreciated.
    Cheers
    I'm just a butcher masquerading as a machinist
    Dec 2008
    3112
    Get hold of PDF creating software
    it can be freeware ( I have PDFcreator (FREEware) )
    when installed you select this option as the printer instead of the your default, set the paper size, orientation, it'll ask for a filename.PDF & location to print it to. and you've got your PDF
    It works like you would do a normal print
    Jul 2007
    72
    Good deal, I was checking out the freeware he other day, but was unsure if I wanted to try it out. I will give it a go thanks for the input.
    Cheers!
    Nov 2006
    418
    What are you trying to create a PDF of? There is the ability to create a PDF in the Set-up sheet tool that is built in...
    I use CutePDF for anything else, it loads like a printer driver so you can use it for any software.
    John
    +1 on the CutePDF. Free and no adware or watermarks.
    Jul 2013
    if you don't want to cost money on pdf creator vb.net ,you might as well search some free pdf software, or you can use pdf printer. there are a few on the web you can use.
  1. How to create surface
    By gorby in forum Mastercam
    Last Post: 11-22-2010, 08:09 AM
  2. Create pdf from bcc V23
    By RMT41 in forum BobCad-Cam
    Last Post: 03-23-2010, 02:46 AM
  3. Create Arc
    By jcnewbie in forum Mastercam
    Last Post: 01-07-2010, 04:28 AM
  4. create 2d toolpath
    By daisydog in forum MadCAM
    Last Post: 02-20-2008, 07:15 PM
  5. create 3d dxf drawing
    By brockadeau in forum BobCad-Cam
    Last Post: 01-31-2008, 03:23 PM
