586,461 active members*
5,267 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > No feed rate error in FeatureCam
    Jan 2009
    I have a Bridgeport Torqcut 22 with a DX32 controller. When I program a part from an IGES file using FeatureCam (v6.0) and load it into the Bridgeport, the mill stalls when I try to run it and gives me a No feedrate specified error message. The txt program looks identical to one that runs fine which I have written using geometry created in Fcam itself; any ideas?
    I am using the torqcutti post processor. Both programs run through the simulation mode in Fcam without problem.
    Jensen
    Jul 2011
    Quote Originally Posted by drj_95018 View Post
    Looks identical at the controller? Looks identical in notepad?
    If so, you have some sort of ghost character in there.
    I had a similar problem. I would re-type the line that alarmed out at the controller and it would work fine. A "Legacy Programmer" (what we call the old guys) I work with recommended opening the txt file with 2010 Word and re-saving it, it worked. I then dug into the post processor and corrected the issue.
    Hope this helps
  1. Feed rate
    By chris123 in forum Taig Mills / Lathes
    Last Post: 07-14-2010, 10:53 PM
  2. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  3. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  4. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  5. Feed Rate?
    By bearwen in forum Uncategorised CAM Discussion
    Last Post: 04-26-2006, 10:52 PM
