586,320 active members*
3,759 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > CONTEST: G540 Redesign Ideas
Page 1 of 4 123
Results 1 to 20 of 75
    Jan 2007
    467
    We are in the process of updating the G540 based on feedback and are looking for ideas that you would like to see in a production version of the drive. What we are adding so far:
    1.) Trimpot redesign: The trimpots are now through hole trimpots located on the motherboard instead of the SMT ones located on the drives. This required a modification of the G250 as well, which allows remote adjustment of the smoothness trimpot. This means that you can use any regular screwdriver to adjust the trimpot and don't have to be as careful.
    2.) Filtered current set resistor: The current set resistor is now filtered, meaning the resistor can be placed on the motor end of the cable with no problems.
    Those are the major additions. Now we need you to recommend what else we need to put on there. The contest is simple: If you are the first to mention an idea and it makes it into the production version of the drive, you win a free redesigned G540. The first one to mention the feature will get the drive, and there is no limit to what we will add (provided it can be done and fits on the motherboard).
    We will base the added features on how badly they are wanted, so if someone mentions something you would like on the drive please say so! The contest will run until we have a finalized PCB layout that is sent off to our board house for a production run. We will post on here when the contest is over and will notify the winners through PM. All winners will be the first ones to receive the drives as soon as they come off of our production line.
    Thanks, and I look forward to see what you have in mind!
    Marcus Freimanis
    Feb 2004
    71
    Marcus,
    How about adding a parallel port connector on the back of the drive as well as on the front.
    Those of us who use a smooth stepper have to either mount the smooth stepper outside the same box as the G540, or run the ribbon cable from the inside to the outside to make the connection.
    It's a small thing, but its the only thing I could think of.
    Royce Bunnell
    OB Cue Shafts and OB Cues
    DIP switches for current setting instead of resistors.
    Jan 2007
    723
    Screw holes on the back used to mount a heatsink would be great.
    A 12 volt power outlet for a common computer dc fan would be a help as well. With the high powered steppers people are selling in kits, these modifications would make things much easier. I know they would have helped with my two installs!
    A rs232 to rs485 convertor would be cool so we could run a vfd from modbus instead of the analog signal.
    More negative power terminals and a ground would help cut down on the mess in back of my machines and help simplify wiring for noobs.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Jan 2010
    2141
    Going beyond just screw holes for a heat sink, how about offering an optional heat sink?
    Also, how about a remote-monitoring terminal (either via digital telemetry or analog signals) that would permit monitoring parameters such as ambient and drive/heatsink temperature, motor current and voltage, vfd voltage and current, all settable drive parameters and switch positions, charge pump operation, whether or not each drive is in standby, LED states, input states and/or voltages for EPO or limit/home switches, whether or not microstepping is in operation, drive serial number(s), step pulse frequency, and the like. If such a monitoring facility were made available, with a published interface (electrical as well as physical connector), then either a variety of standard Gecko remote monitoring devices or third-party devices or DIY devices could be used to view the health of the system in real time, from the machine or from the controlling PC, even if the G540 were mounted inside an electrical enclosure.
    Also, how about an input for an optional MPG or pendant, with the ability to switch between DB-25 control from the PC and control from the pendant?
    And how about an "accessory" +5 volt 1 amp output?
    May 2010
    33
    More inputs. It seems most of the wiring done is a compromise to accommodate only 4 inputs. It would be nice to have home switches, limit switches, speed input and probing inputs all with dedicated ports versus running home switches in series and utilizing software limits.
    I like the idea of an output relay for a coolant pump as well. Moving the inputs to the front of the drive would help me as well as relocating the parallel port to the back. I have my G540 flush mounted into the side of a desktop PC case so it would greatly help the in/out wiring mess and holes.
    Jan 2009
    77
    How about labeling the screw type connector. It would be nice to know which terminal is the power, input, output ... You have done a great job on the front side of the unit.
    I'm lazy, I don't want to print out the manual to wire up another output or input.
    Dec 2005
    238
    Sometimes people want a 5th stepper motor for a rotary axis but because the parallel port pins are all allocated and unaccessible the 5th stepper cannot be added even though not all the parallel port pins are unused. Would it be possible to provide a port to attach an external Gecko drive.
    On my machine I use the Y and A to drive the Y gantry. The software I use does not allow slaving of 2 outputs. The ideal solution is the ability to have some internal links within the G540 to drive bothe the Y and A drivers from the Y input (pins P4 & P5) and pass through Pins P8 & P9 to an external plug to drive the 5th stepper via an external driver, eg G201. This also eliminates the need for the PC to do the slave function and any possibility of lost steps due to PC's inability to output to both ports correctly.
    Change the main terminal block to unplugable types.
    I like all the ideas posted so far. The ones proposed by Gecko will be great to start. I also vote for the 12 volt output for a fan to cool the Gecko but instead of heatsink mounting holes I think mounting holes for 1 or 2 computer fans on the back of the unit to cool it. The fans could be screwed straight to the rear of the unit with washers for spacers to hold it off the back to allow air flow.
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
    May 2007
    781
    How about an adaptor board that plugs in in place of 1 or more of the G250 boards.
    The adaptor would pass the signals out so that one of your other drives could be plugged in. So a system could easily be built with say 2 or 3 smaller steppers and 1 big servo.
    Liking the cooling fan power and mounting.
    Jan 2007
    723
    A 50 or 48 volt 20 amp solid state relay prewired to an output pin or switched on and off like the charge pump feature would help people with spindle wiring and/or cooling.
    Obviously the high current terminals would have to be beefy and the relay is quite large compared to the gecko 540 case.....
    It was one of the first things I set up after the motors. I have one CNC router configured with 2 relays one for a router and one for a vacume. The other CNC machine uses the same type of relay to control a vfd!
    Every machine I build uses the same type of relay for spindle or accessories.
    Apr 2005
    438
    USB interface to replace the current rs 232 parallel interface or add USB interface in addition to current rs232 parallel interface. One more "or" release two versions of the G540 one USB, one rs232 parallel interface.
    Oct 2006
    44
    1) Change DB9’s to plug-able screw terminal connectors or as an alternative offer an accessory daughter board with mating DB9's with motor connections brought out to screw terminals.
    2) Offer correct length mounting standoffs as an optional accessory.
    Dec 2005
    238
    Include a temperature sensor in the G540 in addition to the suggested 12 volt power supply to drive a fan. This will stop the 12 volt supply being used for other things that it isn't designed for and only run the fan at the necessary speed or turn it on and off to cool the G540. Just like a computer PSU.
    Also the Temperature sensor could set the G540 into a fault condition if it overheats.
    The following is just a general comment on sizing.
    If possible I would like to see the G540 remain the same width as this fits nicely into a standard PC Case drive bay. If it has to expand then deeper rather than wider would be better in my opinion and if it ended up exactly 2 bays deep rather than it's current 1 1/2 bays that would be magic. I suspect quite a few people build theirs into PC cases because they have them laying about. Some additional screw holes in the side to mount them in a PC bay wouldn't go amiss though the 4 mountings at the front are just as good.
    Cheers
    Peter
    Apr 2010
    Great! Looking forward to whatever updates come! I've had a number of "wishes" for the already-super g540 that I've collected for a while now. There are a lot and many are more feasible than others! Here they are:
    1) A higher-voltage version of the g540 - essentially a version of the g540 that uses g203s or g201s as the drivers rather than g250s - this is a big one, but these woudl sell like hotcakes!
    2) Optional "ribbon" type parallel connection in addition to the standard parallel port connection - the port would allow smoothstepper users to connect the smoothstepper using a regular ribbon cable
    3) Connection pins for all parallel port pins (all inputs and all outputs)
    4) 5 volt and 12 volt outputs for accessories (1 amp or as much current as is possible)
    5) external enable output - for connecting other BoBs and tying e-stop signals and other faults together
    6) Software programmable/updatable - allow the end user to apply firmware updates
    7) Software-set current settings - get rid of the current set resistor and allow the end-user to set this through software or some other simple way
    8) Built-in cooling - I like the idea that others have suggested in a separate "add-on" heatsink/fan, but I think the g540 should be a compete package as much as possible, and gecko's research has clearly shown that cooling is essential. I would consider fattening the case a bit and adding a small, efficient fan as part of the standard package
    9) Standard fuse and fuse bracket than can be easily replaceable by the end user
    I think that is all of them (for now anyway). Looking forward to the new g540 and other new products from gecko!
    :cheers:
    May 2005
    1662
    Quote Originally Posted by mklb View Post
    +1
    Ribbon cable on back, not D-sub please.
    I like the present situation with the current set resistor, as part of the cable/connector rather than integral to the G540 itself. Resellers can (and do) provide ready to run cable/motor combos. This may be a minority opinion, I remember Mariss floating the idea of dip switches when the G540 was first introduced.
    Jun 2005
    35
    My biggest issue is the location of the screw connectors. When mounted in a controller box. I have to "unmount" the G540 to gain access to the screw connectors.
    Thus, either move the screw terminal connector to the "top" of the case or 180 degree your case labeling.
    Ken Serdar
    Jun 2005
    35
    +1 on the heatsink, fan, sensor.
    Jun 2008
    467
    Lightbulb Make the parallel port backwards compatible
    Make the parallel port backwards compatible for all the customers that have older computers. Adding a few resistor's would eliminate a lot of unnecessary tech support.
    JoeyB
    A doughnut a day keeps the doctor away.
    Jul 2011
    Here is my 2 cents for redesign of the G540
    You ask for it :
    - Redesign the G540 by imagine you are the user , How would do you feel to do the soldering for DB9 with a resistor . Don't design something that any user would curse at the designer because of stupidity . How a bout a premake DB9 with an ajustable resistor and a nice shield .
    - How about an easy to open G540 with just 4 screws .
    - How about an easier trim .
    - How about no voltage on pin 67 when charge pump is off.
    -How about hire somebody to test the product and tell you the problems in a user perspective .
    By all means please charge more : I rather pay you an extra $200 , I save me alot of time and efford to wander around asking for help .
    make American proud , design a new G540 like a rock with a spirit of Iphone 4 in mind .
    Think of the user first , make them happy and the cash will come.
    My 2 cents
    Jan 2007
    723
    I really like the resistor settings on the db9 connector. It gives you a lot more freedom when choosing motors. Besides, there was a big thread a few years back about setting the current values and this method goes with their current product lineup.
    An improvement would be putting some common values of 1% resistors in the package so people would have an easier time finding the correct values and easing the additional expense and time required to find them on your own.
Page 1 of 4 123
  1. Redesign of JGRO in Denmark.
    By pulsar200 in forum Commercial CNC Wood Routers
    Last Post: 09-02-2006, 09:19 PM
  2. Driver contest
    By cncadmin in forum Community Club House
    Last Post: 02-16-2005, 10:36 PM
  3. Driver contest anyone?
    By Mariss Freimanis in forum Servo Motors / Drives
    Last Post: 02-16-2005, 02:53 PM
