586,596 active members*
3,035 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Thread forming (roll tapping) tips please
    Sep 2007
    8
    Hi all,
    I need to roll tap m3 x 9 deep in st/st 316. I'll be using a tin coated hss m3 thread forming tap and drilling 2.8mm. I cant afford to break one!
    Any tips would be appreciated? Speeds for example? It will be done on a haas vertical milling cnc machine.
    Mar 2010
    Verify the you are using the correct drill size for the tap. (Check with the manufacturer) They usually different that the drill size for cutting taps. Fastest way to break forming taps.
    Mar 2006
    2712
    Get serious with the tap lube. Forming taps extrude metal into form and consequently need good lubrication. But you knew that.LOL
    Dick Z
    DZASTR
    Jan 2007
    1389
    Try emuge(sp)taps for 316 I believe they make a roll tap.
    make sure you hole size is to the maximum minor dia before tapping.
    even though its only 9mm deep you may have to peck tap it twice.
  1. Roll form tapping questions
    By stebanski in forum Haas Mills
    Last Post: 05-11-2011, 10:12 PM
  2. Roll tapping.
    By Mitsui Seiki in forum G-Code Programing
    Last Post: 06-17-2008, 05:37 AM
  3. Roll form thread die wheel question...
    By niggle in forum MetalWork Discussion
    Last Post: 06-11-2008, 06:10 AM
  4. Thread Forming
    By rrrrrgh in forum MetalWork Discussion
    Last Post: 07-27-2005, 09:50 PM
