586,440 active members*
4,224 visitors online*
Results 1 to 6 of 6
    Aug 2021
    17
    Sinumerik 810m/820m/880m/850m drip feed (DTR) how to
    Hello everyone owners of Sinumerik 800's cnc system.
    A lot of times, i saw messages, which ask "how to" enable BTR/DTR/Drip feed.
    I also saw Siemens forum, which some of members told, that this is impossible or it must be paid separately. Today, i want to finish this discussion, by my short thread.
    Ok. Let's start.
    1. Drip feed/DTR/BTR can to be enabled without any problems or magic, on: all Sinumerik 800's GA3 version.
    To do it, you must to:
    1. Go to the MD bits in manufacturer mode.
    2. Find MD5016
    3. Bit 7 must to be changed in "1" position. So, MD5016 will be look like 10000000 or 11000000 if you want to use Xon/Xoff secured transmission.
    4. Reboot machine.
    So, you will got BTR available just configure your port to get data input.
    If you have GA1/GA2, maybe, you will not have BTR in DATA IN-OUT.
    So, you will need to:
    1. Back up all data! PCP, PCA, TEA1, TEA2, Cycles, Tool change cycles, user memory and Part Program memory. ALL of them.
    2. Buy GA3 IC module. It's pretty cheap. Like this one:
    6FX1822-0BX04-2C, with correct language pack.
    3. If you didn't found it, i can to read this IC's and upload firmware, to flash your old.
    4. Reload the all data, and start machine
    Aug 2021
    17
    Re: Sinumerik 810m/820m/880m/850m drip feed (DTR) how to
    If you need to unlock any other options, for Sinumerik 810, please, write in PM.
    May 2015
    8
    "SovietTwins has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
    Aug 2021
    17
    That's strange.
    Try to PM me again or wite me e-mail at terion(six_six_six (write three numbers))@mail.ru
    May 2015
    8
    Hello!
    I looked at the documentation of both GA2 and GA3 systems. And in child versions EPROM submodule: (Standard UMS standard cycles) is the same.
    GA2-6FX1 822-0BX03
    GA3-6FX1 822-0BX03
    I bought a "Siemens 6FX1822-0BX04-2C Memory Module" and now I'm looking for which memory to replace it with
    Quote Originally Posted by SovietTwins View Post
    Ok. Let's start.
    2. Find MD5016
    4. Reboot machine.
    May 2015
    8
    I put a 6FX1822-OBX04-2C module on slot 3, but the system gives an error "11 falche asm kennung"
    My sistem is Siemens 810M GA2
