I was trying to make a tooling plate. I used the Dolphin CAM "canned cycle", for drilling "points on a rectangular grid". I use Mach3 so I did the post processing with the Mach3 post processor choice.
I loaded the Gcode file into Mach3 and got an error:
Cannot use two g codes that both use axis values Line 5
Is there a way to fix or avoid this?
I've attached a screen cap. The error message is at the bottom in the "Status:" window. The G code is in the upper green window, the program has highlighted the line causing the error.
Thanks for any help.
David
