Originally Posted by
Delw
Dj
I ran the g13 right after I made the last reply,Cause you know how it goes a jobs running pretty good and why not just try something new LOL WOW thats pretty badass.,
I dont run too many canned cycles, I do most of everything in cad. but the g13 is great cause you can just take your drilling cycle(center points) modify it and use it for the g13.
Thanks again for all the help.
Delw
The G12 and G13 codes are very powerful and so easy to use. I use them so often that I keep a program on the control that is titled G13.
Easy to program, can use steps in size and down is Z axis.
Example: G13 G91 Z-.5 I.400 K2.0 Q.400 D01 L4 F20.
With a 1/2 inch endmill that would bore a 2.5 inch hole 2 inches deep with a step of .2 each pass and an initial hole size of 1.400. So easy!
If you do use the "L" for multiple passes in "Z" depth, make sure to switch back to G90 and clear the tool from the hole! This is one of the few canned code that does not retract from the hole when it is finished like all the drill cycles and such do. You always must retract the tool from the hole before moving to a different location.
Mike
