586,732 active members*
3,546 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam & Inventor files
    Jun 2010
    Anyone experiencing problems generating good nc code from an inventor solid? We are using 2011 R2. Post may have issues, but I believe it should work.
    Trying to machine a face and a diameter (o.d.) with a 3/4 end mill. Using the solid to define the profiling cycle generates hundreds of lines of code and the G2's & G3's are not specified correctly - CPL is the centerline of the part so I's & J's should come out as I0, J0 unless the radius being cut is a lead in or lead out. Machine being used requires absolute values for I & J.
    For arguments sake, we projected the diameter & selected wireframe - used the same profiling cycle to recut the same feature - NC code looks perfect.
    Anyone have a clue if this is software related or do I need to get to work on the post processor?
    Jun 2010
    60
    Have you tried making the tolerance smaller? i have seen that edgecam loves straight lines and it opts for 100 segments rather then a circle as soon as the tolerans is to low.
    I dont have Inventor this was just a "thought on the side of things"
    Aug 2011
    not an edgeCAM seasoned person but am certainly an inventor professional...
    For instance, when working in inventor the default finite precision point is to 4 thousanth of a micron and, knowing the basics of operations with Citizen M32's this can cause problems and usually does when working with surface toelrances with MMVT or MMT on milled parts.. ive certainly had this when working with investment casted parts for oil rigs.
    The only solution is that to reduce the tolerances in the Inventor Part of assembly file. youve statd that you cannot do this as you dont have inventor, but the should be a primary Excel sheet with the inventor file youre working with. You can change it there assuming you know what your doing...
    Other than that, all I can suggest is look at the first principle draft, and manually input the amended tolerances in. However im not an EdgeCAM specialist, so I dont know how this is done...
  1. Inventor & EdgeCAM scribing text
    By 80083r in forum EdgeCam
    Last Post: 05-09-2014, 07:44 PM
  2. Anyone have Autodesk Inventor X3 Cad files?
    By caleb105 in forum Benchtop Machines
    Last Post: 02-16-2009, 08:11 PM
  3. Convert files to Inventor files.
    By bartL in forum Autodesk
    Last Post: 02-04-2009, 06:38 AM
  4. Inventor Ext Threads into EdgeCAM
    By RMalloy in forum EdgeCam
    Last Post: 12-19-2006, 10:39 PM
  5. Inventor Part Files
    By vladdy in forum Autodesk
    Last Post: 04-04-2005, 03:59 AM
