587,006 active members*
3,073 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Finding the centre of a small countersunk hole
Results 1 to 8 of 8
    Jun 2011
    13
    Hi All
    I need to find the centre of a countersunk hole which has been cut into a piece of 3mm thick brass - the hole is 3mm in diameter and the countersink is 5.5mm in diameter.
    So I was wondering if there is a tool that will be small enough to find exact centre.
    Iano
    Nov 2010
    Quote Originally Posted by Iano View Post
    Hi All
    Iano
    You could use a tiny probe and Hoss's probing utility. It has a great center-finding function.
    Feb 2011
    110
    Heres how I have done it. Get a 3mm dialpin about 1" long stick in the hole then put in the mill vise Bring the quil down and move so you can chuck the pin in drill chuck. then adjust till you can slid pin in and out with quil.
    Use the pointy end of an edge/center finder.
    Put the tool on the chuck, turn it on slow, feed it down till it touches the inside of the hole,
    adjust the x and y till it runs true.
    LittleMachineShop.com - Edge and Center Finder
    A wiggler works too.
    http://www.littlemachineshop.com/pro...ory=1261091193
    http://www.littlemachineshop.com/vid...erKit30fps.wmv
    Hoss
    Jun 2011
    13
    Hi thanks guys - will try them ideas out.
    Iano
    Dec 2010
    1230
    I would use a center finder as hoss said. LMS also had the starrett center-edge finder for $23.
    LittleMachineShop.com - Edge and Center Finder, Starrett
    I bought the cheap one from LMS and it developed/had a burr on the center finder side that prevents it from running true. $25 for a tool that will last a life time is a good deal.
    Aug 2009
    899
    If you don't have a center finder a crude way of doing it would be to put a 3mm drill bit in your spindle (NO NOT TURN SPINDLE ON) and adjust your x/y until you can slide the bit through the hole..... not the preferred method but it works.
    Sep 2010
    11
    At the end of this video is a clever way to do this (5.45)
    [nomedia="http://www.youtube.com/watch?v=J4EtmJhDYHQ&feature=mfu_in_order&list=UL"]YouTube - ‪Machining the Model Stickney Engine with Lathe and Mill‬‏[/nomedia]
  1. Finding exact centre of 3mm hole
    By boxmaker in forum Benchtop Machines
    Last Post: 11-19-2010, 02:46 PM
  2. Another Aussie Adventure in Optical Edge/Centre Finding
    By Greolt in forum Mach Software (ArtSoft software)
    Last Post: 04-01-2008, 09:48 PM
  3. Finding the centre of an arc
    By Robin Hewitt in forum G-Code Programing
    Last Post: 03-28-2008, 02:02 PM
  4. How to drill a centre hole accurately.
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2007, 04:31 PM
