586,925 active members*
2,741 visitors online*
Thread: Poor finish
Results 1 to 17 of 17
    Oct 2009
    23
    Poor finish
    When milling a profile, it seems that I am getting the better finish on the wrong side of the cut. If the spindle goes CW and the cut is going CCW, why is it that the outside has a better smoother finish than the edge of the part I intend keeping?
    May 2010
    313
    Quote Originally Posted by LLDesigns View Post
    try it with a climb cut instead.
    John
    Oct 2009
    23
    I understand that i can change the direction which becomes a climb cut, but is there a reason why it does this?
    Mar 2007
    534
    CCW outline is climb milling, the cutting forces bend the tool into the workpiece. Cut downhill and the tool shies away from the workpiece so there is metal left for the finishing pass.
    Pic is two similar parts, top climb mill bottom conventional
    Oct 2009
    23
    Thanks for the explanation. Makes more sense why it happens
    Mar 2007
    534
    There is a snag...
    Downhill cutting is more likely to "grab" if the tool is not cutting it's full diameter. ie: not slottting. You really need to eliminate any backlash before using it.
    Mar 2007
    534
    Maybe I should expand on that a bit...
    If you are climb milling the nut driving the axis pushes the tool against the workpiece. The tool pushes back against the nut. Everything is hunky dory.
    If you are conventional milling the nut pushes the tool against the workpiece and the slide is instantly drawn on to the tool through the backlash. Clunk. The nut catches up and it repeats. Your finish is a series of vertical lines.
    Apr 2005
    862
    I think you have those in the wrong order. Climb milling is where the tool tries to climb over the cut - it pulls the workpiece in the direction of feed. It gives a better finish because there is less chip re-cutting and because the chip starts off thick and ends up at zero thickness as the tooth completes the cut.
    With conventional milling, the chips are dumped in front of the tool and can be recycled into the cut again. Also the tool will tend to pull laterally into the cut too. When milling with a machine with backlash, generally the advice is to use conventional milling to rough out the part and then skim off a thin finishing allowance with climb milling. As long as the allowance is small, there will not be sufficient force to pull the table through the backlash and you won't get any nasty surprises. With CNC with no backlash, pretty much all cuts are climb milled. It requires less power, tool life is usually better, and the finish is superior.
    LongRat
    www.fulloption.co.uk
    Mar 2005
    335
    and to add to the perfect text book answer is that you might consider conventional milling is there is an abrasive skin on the part which might damage the tool. by conventional milling the skin the tool breaks the material away rather than coming in contact with it.
    Mar 2007
    534
    Quote Originally Posted by LongRat View Post
    Perfectly possible, I was taught uphill, downhill. Uphill you push against the tool, downhill it helps you on your way.
    I thought climb meant uphill but I've probably got it wrong. Doesn't worry me, I'm an old man with a full order book
    Jun 2008
    614
    Quote Originally Posted by Robin Hewitt View Post
    Easiest way to remember it...with "climb" cutting the tool tries to climb up the part!
    http://www.g0704.blogspot.com/
    Oct 2009
    23
    It seems as though in either direction, I am not getting the finish on the side that I would anticipate. The side end up not being smooth. It just seems that it is rough on the edges. What causes this?
    Aug 2009
    986
    It might be related to the part and how it is being fixtured. Can you post a picture of your setup?
    Frederic
    Dec 2009
    1416
    Or a pic of your results? Any item milled on the side will have some scalloping in the finish, at least any that I have seen. The faster you feed into the cut the bigger the scallops. If that's what you are referring to that's just a side-milled finish. Now if they are really big or uneven or there's fuzz and stuff that can all be other issues. Tough to say what a bad finish is since it's all relative. A picture would help a lot.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Oct 2009
    23
    Being the newbie that I am to milling, i did not think that i would have to make a finishing pass. I did a setup with a finishing pass which made it look all nice and neat. Thanks
    Dec 2009
    1416
    Oh yeah, a finish pass is always a good idea. It's amazing how much the cutter can bounce around on a heavy pass or especially in a full slot.
    Sep 2005
    371
    Have you properly trammed your mill? Remember the head MUST be trammed to the column itself.
    Look around the net. There's lots of info.
    Due to not being in tram, I wound up with horizontal lines in my aluminum because the bit was moving slightly off the correct location the farther down into the material it went. Good on one side, but bad on the other.
  1. Steel Ring Egg Shaped and Poor Finish
    By LaysMachinist in forum Material Machining Solutions
    Last Post: 03-01-2011, 07:32 PM
  2. BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar)
    By zerodegreec in forum Benchtop Machines
    Last Post: 09-14-2010, 09:01 AM
  3. poor surface finish
    By sinha_nsit in forum CNC Tooling
    Last Post: 02-17-2010, 04:48 AM
  4. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
  5. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
