586,129 active members*
2,783 visitors online*
Thread: L297 - L298n
Results 1 to 6 of 6
    Aug 2011
    L297 - L298n
ID:	139204Hi everybody.
    I have problem with wiring L297 - L298n. I did everything as in datasheet but i didn't get anything but a burning smell.
    Can someone please tell me what did i do wrong?
    I am trying to control bi-polar stepper motor by sending pulses from parallel port to L297
    CW/CCW , half/full step ,reset , enable and Vref are connected to 5 volt
    Control to ground
    I am sending pulses to Clock from parallel port ( 3-3,5 volts )
    Instead of 36 volts i am using 24 volts.
    I have 4 wired stepper motor and how can i connect them to L298n?
    Jul 2005
    28
    L297/298 help
    RS1 and RS2 should be 0.5 Ohm resistors rated at least 3 Watts, preferably 5 Watts.
    Vref should NOT be connected to 5V! The voltage on the Vref pin sets the motor current per this formula: Stepper motor current (Amps) = Vref(volts) * 2.
    For example, to set the motor current to 1.0 Amps per phase, the voltage applied to Vref should be 0.5 Volts.
    The Vref voltage is usually derived by using a resistor divider from the 5V. Using a potentiometer in the resistor divider lets you adjust the Vref voltage.
    ED
    Aug 2011
    Thanks.
    I check the the motor and it needs 6.4 ohm so i need Vref 3.2 volt.
    I build is again but this time without L298n and and i put 4 leds to the output of the L297.
    First i put them between every pin and ground ; but only 2 of them worked , also i changed the CW to high but the same and when i send pulses to clock they went off.
    Then i put pair for each output ; one pair between 4 and 6 numbered pin but opposite directions ; same same....
    Why can it be?
    Mar 2011
    Hello
    please download datasheet of L297 from http://www.st.com/stonline/books/pdf/docs/1334.pdf .
    Page 7 clearly mentions that VRef maximum voltage is 3.0Volts!
    Use the following formula VRef = Ohms of Sense Resitor * Motor Amps
    Jan 2008
    5
    Stepper
    Please use ref less than 5 V Dc say 2,5 V.
    Use non inductive sense resistors.
    May 2014
    2
    Re: L297 - L298n
    after about 6 years !!!!
    there is too expected errors,,,
    first check the software you use , setting , options , port option , you'll find inverting port signals,
    be sure that all the board you use were wired correctly.
    important : try to make a test for you lpt port using LEDs
    important 2: test the driver board yousing digital signal using 555. this will avoid damage your pc.
    mmmmm hope that's useful, (feedback plz)
    [email protected]
    00972599896772
  1. Parallel L298N driver circuit help
    By Sidco7 in forum Stepper Motors / Drives
    Last Post: 03-01-2011, 04:56 AM
  2. L298N and L297 for stepper motor (unipolar)
    By same79 in forum CNC Machine Related Electronics
    Last Post: 12-27-2010, 06:01 PM
  3. l297
    By harshasunder in forum LinuxCNC (formerly EMC2)
    Last Post: 01-09-2010, 08:09 PM
  4. L297 for unipolar?
    By Mcgyver in forum Open Source Controller Boards
    Last Post: 12-10-2005, 07:13 PM
  5. L297 / L298n problems - whining motor!
    By bigal in forum Stepper Motors / Drives
    Last Post: 07-21-2005, 10:32 AM
