586,426 active members*
3,195 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020HT metric or not?
Results 1 to 13 of 13
    Nov 2007
    78
    Hi!
    I'm a newbie on the fadal here in germany. We have a 4020HT (MY 1999).
    The CNC-Control is in english, the digits of the axis-positions are metric.
    The parameter in SETP Page 2 (DEFAULT) is set to metric.
    Wondering if I jog with the remote-control one digit, axis jog for
    example 0.254 millimeters if the knob on the panel set to 0.1.
    Is this correct? I think, there is a 0.1 milimeters-moving correct.
    Bye
    Thomas
    180
    I can only speak for the CNC88HS controller.
    When set for .01 each increment is .254mm
    .001 = .0254mm
    .0001 = .00254mm
    I found this information in the Training Manual
    Nov 2007
    78
    Hi!
    I have the 88HS.
    Yes, you are right:
    .01 is .254mm
    .001 is .0254mm
    and
    .0001 is .00254mm
    It's not a big problem, but a litte strange for a metric german machinist.
    If I have to jog for example 20 mm - it's better to use MDI-Mode....
    You wrote "training manual". Is there a link to download it?
    Another question:
    is there a chance to put the tool back to ATC after the programm
    is ended? On the Ultimax (Hurco) I can manual set "next" Tool to 0
    and the machine put the tool back. I don't want it do to it in the program,
    the manual way (command...) is okay.
    Bye
    Thomas
    180
    I'm a newbie too so you've been warned.
    Try TC,1
    I'm not at the shop today but I'm pretty sure that's the command you're looking for.
    Cardinal Machinery, Inc. - CNC Metalcutting and Fabrication Equipment - Locations in Tennessee and Alabama
    I don't see a Training manual but the Operator's manual looks similar
    Nov 2007
    78
    Hi!
    TC,1 open the ATC - that's right. But if you press MANUAL, the
    machine take the tool again.
    Bye
    Thomas
    Mar 2010
    atc
    you can use tc,1 and then hit cw or ccw keys to move the turret to an open pocket then press manual again to come down on the empty pocket.the manual can be downloaded at fadal.com it is hidden a bit,here is now to get it.go to fadal.com,hit products+services tab,then hit services tab,then fadal manuals.they do have some in german for you.you also can go to fadalcnc.com and get even more manuals,but no german ones.
    Jul 2009
    317
    Asumming you are using 4 tools (1-4); before the end of the program (M2) insert a line M6T21; the tool go to #4 bucket, and the turret jumps to #21 wich is an empty pucket. Or inset M6T1, tool 4 go to 4# bucket and turret picks up tool #1.
    Nov 2007
    78
    Hi!
    Funny tricks!
    I understand correct: there is no "normal" way - to clear the tool in the spindle
    like TC, 0?
    Bye
    Thomas
    Jul 2011
    105
    Hi ! NEW KID too....
    Have the same gear here .... [nomedia="http://www.youtube.com/watch?v=34C9bGDYkoY"]‪Fadal 4020 tool change with some noise...‬‏ - YouTube[/nomedia]
    Apr 2008
    87
    What do you mean by "clear the tool in the spindle"? What are you looking to accomplish?
    Jul 2011
    105
    Red face clear
    I guess clear the the tool means that getting it out from the spindle. Like crearing the cone from the holder.
    :bat:
    Nov 2007
    78
    right - I want to set all tools back in the atc so the spindle
    is empty
    Aug 2006
    52
    I prefer to leave a tool in the spindle whenever the machine is powered on. This is so that if I use air or a coolant hose to clean the inside of the machine, no chips will make their way into an open spindle.
    When I go to turn the machine off, I do manually release the current tool (tool in/out button) and leave it on the table, so it will go back in the machine when I turn it on again. I leave the tool out when he power is off so there isn't a load on the belleville washers used in the tool retention mechanism.
  1. 4020HT - question
    By MBX5 in forum Fadal
    Last Post: 08-20-2010, 06:17 PM
  2. 1995 4020HT lube?
    Last Post: 04-08-2010, 02:35 AM
  3. Adding 4th axis to 4020HT
    Last Post: 07-27-2009, 05:17 PM
  4. Fadal 4020HT arcing
    By sullione in forum Fadal
    Last Post: 07-27-2009, 04:03 PM
  5. Looking for a use 4020HT with rigid tap
    By REVCAM_Bob in forum Fadal
    Last Post: 05-13-2006, 07:50 PM
