586,546 active members*
3,147 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help How do you call this dual size Bolt (Picture Included)
Results 1 to 8 of 8
    Mar 2008
    28
    Hi, Ho do you call this dual size Bolt? One size the thread is clockwise the other size is anti clockwise
    My intention is two built a Gradual platform Similar to this (When I turn the Bolt the distance is shorter or greater depends of the direction):
    if you can also point me where to buy it would be great.
    Feb 2006
    794
    I would call it a turnbuckle.
    Don
    IH v-3 early model owner
    May 2010
    118
    You can get them in small sizes (4-40, 6-32, metric equivalents) from any hobby shop that deals in parts for RC cars. They are used to adjust suspension alignment. Not sure where to go if you need larger.
    Aug 2010
    Andycorleone,
    From the photo, it can't work. A turnbuckle has a threaded rod with a RH on one-half the rod and a LH on the other, and uses two nuts to follow the threads; one LH and one RH. The nut shown in the drawing would only have a LH or RH thread. Would it be easier to mount the nut on the lower plate and just turn the screw to increase or decrease the distance between them?
    I have seen duel threads of two different pitches, (same direction) where one will move relative to the other and used to make very fine or precision adjustments. The nuts have two pitches cut into them, half and half. All of these have a limited travel. If you design a tube, (say 4 inches long) and mount two nuts of different rotations (LH and RH) on the ends of the tube. Then mount threaded rods to the plates, turning the tube would accomplish your goal. Here are two links for examples
    Eye & Eye Stainless Steel Turnbuckles : Ratchet Straps, Tie Down Straps, E Track Tie Downs, Moving Blankets & Pads, Cargo Straps, U.S. Cargo Control
    TURNBUCKLE DIN 1478 - Product Picture From Qingdao Su Mei Da Machinery Co., Ltd.
    Joe
    Mar 2008
    28
    thanks for the help I will look for some
    Feb 2010
    Mar 2008
    28
    Quote Originally Posted by APinSoFla View Post
    Thats the one thanks
    Apr 2024
    1
    Re: Help How do you call this dual size Bolt (Picture Included)
    Being a truck driver for 5 years now, I am personally using these types of equipment and would like to recommend these.
    https://www.myteeproducts.com/liftin...g/rigging.html
    https://www.myteeproducts.com/auto-t...ng-straps.html
    https://www.myteeproducts.com/genera...et-straps.html
  1. Replies: 2
    Last Post: 12-10-2010, 07:27 PM
  2. How were these holes milled? Picture included
    By Micro Milling in forum MetalWork Discussion
    Last Post: 11-26-2009, 02:15 AM
  3. NEMA 23 & 34 Bolt pattern & end frame size in. measurements
    By millman52 in forum Linear and Rotary Motion
    Last Post: 05-04-2009, 05:41 PM
  4. I'm recutting chips right? Picture included
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 03-31-2009, 02:50 AM
  5. Bolt size ?
    By dropride in forum Bridgeport / Hardinge Mills
    Last Post: 06-17-2008, 12:38 PM
