586,974 active members*
3,389 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > 4th Axis Feed Rate Problem
Results 1 to 11 of 11
    4826
    This problem may be dependent on your machine controller's specifications. What kind of machine? How are solitary A axis feedrates to be commanded: what units?
    Typically, simultaneous XA moves will be controlled by the X axis linear feedrate (both axis must start and stop at the same instant), but A axis movements may need their own feedrate command, and it might have a degree/min requirement.
    May 2003
    96
    Hi. What software are using to drive your CNC? Is it the same software that you use to designing / create your cutting paths with?
    Martin G
    Oct 2004
    159
    Martin, I am running Mach3 on a Tormach PCNC1100. Right now, I am reading up on axis scaling and radius correction in the Tormach manual. I haven't gotten back to the machine to check out the new settings. One thing I notice is that the numbers engraved before the cutter goes *ping* seem to be the correct width. I'm wondering if changing the A-axis scaling will compress the width of the numbers. We'll see.
    May 2003
    96
    hi. is the encoder ppr setting in mach3 entered with the correct value? your problem sounds likely to be the culprid.
    Martin G
    Oct 2004
    159
    The ppr setting in Mach is certainly one thing to check. The immediate question, though, is why the A-axis feedrate calculated by Sprut is so high. (This is before the G-code gets anywhere near Mach). I'm thinking it may have something to do with the Tormach post-processor or with one of the Tormach xml files. Clearly, I have a lot more digging to do.
    If anyone from Tormach is reading this, please feel free to chime in.
  1. Z-axis feed rate
    By Richotech in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2009, 03:13 PM
  2. Feed rate problem
    By Rene Nuñez Paz in forum Hobbycnc (Products)
    Last Post: 03-09-2009, 01:50 AM
  3. Mach3 with Taig Motor Feed Rate Problem
    By alt255 in forum Taig Mills / Lathes
    Last Post: 12-13-2006, 08:50 PM
  4. Feed Rate Overide problem
    By Moondog in forum Machines running Mach Software
    Last Post: 06-14-2006, 11:35 AM
