"Is this the design with the bearing ball providnig vibration? How did it work out for you?"
-Yes it worked pretty good but when the molds get bigger you really need a strong vibrator.
"What were your thought about putting the unfinished side of the EG saddle uppermost? I would have thought that the unfinished part of a mould would be better hidden below."
-It would have been nice with a smooth surface on top but the angeled surfaces underneath forced me to do it this way.
"What was the mould material? What mould release agents did you use, did they work well?"
-I don't know what its called in english but its a wood-based board.
I painted it and then waxed the surface but the damn thing wouldn't come loose.. I ended up smashing the mold :tired:
So its a no on the last question
A small note,
Its only the plate between the X and Y axis (or do you say axes?) thats made of E/G
