587,036 active members*
2,946 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > SHAME ON HAAS!!!!!!!!!!!!!!!!
Results 1 to 20 of 38
    Jan 2007
    26
    :devious:SHAME ON HAAS!!:nono:
    Just bought a new EC 1600 with a full 4th in the table. This thing cost around $250K and you would expect to get something that would at least work as good as our $70k fadals. I would not tell anyone that wanted to hold under .002 (yes .002 not .0002) on the rotary to buy one. The factory tech even came in and tells me that is just the way it is, you will have to go past the postion in one direction and then come back to it in the other direction taking out the backlash. We have 25 cnc machines with 4th axis and not a single one of them has that much backlash, or at least a way to adjust it out. We have a 1983 toshiba that is not this bad. Can not even begin to tell what a dissapointment this machine is. SHAME ON YOU HAAS.. why would you even make a machine in this day and age that would not hold .002????
    Aug 2006
    69
    You need to call the factory in Oxnard and escalate this issue. Asking it to hold .002 is not asking for much, and I would be pissed too.
    Call the 805-278-1800 number and try to get someone who knows something.
    Jan 2007
    26
    There is a factory man from Oxnard here now, his is the one telling me that I will have to go past the postion and back to it to remove the backlash in the rotory.
    Apr 2005
    903
    What are the advertised specifications?
    2008 Haas VF2D
    OneCNC XR5 Mill Expert
    Mar 2010
    1852
    I can understand your frustration, but it's time to stop ranting and just deal with the issue. Posting here does not deal with the issue very effectively, unless your intention is just to bash Haas. No company is perfect and no piece of equipment is perfect. Overall, those of us who have our Haas machines are very happy.
    I do not know what the spec's are on the built in rotary in your machine, but I looked up the spec's for an HRT210 and it was 30 arc-sec of backlash. That does not seem like much, but it is 120th of an arch minute or .0083 degrees.
    Over the 28 inches you say you are trying machine, that equals .0041" of deviation. Then you can add on the accuracy and repeatability of the unit. It makes sense to me to do as recommended and remove the backlash with the procedure recommended.
    On the ways of the machines the recirculating ball nuts can take the pressure because they are always rolling and not rubbing, but on a rotary axis the is always rubbing between the worm and the gear. If you make the pressure too great, in order to remove the backlash, the gears will fail. Then of course you have other connections between the encoder and the actual table surface.
    I hope that you get the issue resolved, but I think that setting it up by dialing it in and setting the A axis and not some parameter would be more accurate and repeatable.
    Best of luck with your issue.
    Mike
    Oct 2005
    114
    I have to say, getting on the interent and bashing a company is about the standard today. You never hear anything good about a company , just that bad. If peoples attitudes were better, you would be amazed at the help they would get.
    Anyways, we own a trunion table from haas. The rotary specs are about the same as what you have. We use the table to machine cylinder head ports, 5 axis motion, very comlex stuff, probally alot more complex than most users would ever perform. The table was not repeating since day one, we had problems with the 2 machined ports not linning up, machined from opposite sides.
    After looking the problem for a very long time, we took it upon ours selfs to fix the problem. We had talked to haas on the issue, and they had gave us some insite. The table specs were what they claim. Real life use is, you have fixtures and maas on the table, the alters the repeatablility. The is a comp table in the control, were you can adjust the comp on the table. After some trial and error testing, we were able to get the table 100% dialed in.
    The Hass is very nice machine, nothing is perfect out of the box.
    Good luck.
    HAAS VF3-5 axis trunion
    Mastercam X3
    Jan 2007
    26
    We have 6 other haas machines and very one of them is fine, they all have a rotary on them and I have no complaints. As for ranting.. you spend $250k for something and dont get what you pay for. And this whole post is to let others know what they might expect can happen to them, Something I wish I had known before now
    My parts have to be closer than that, and my 28 year old toshiba will hold it, so why cant the haas
    We have 26 rotarys, I know how they work and none of them have this much slop.
    It will not repeat to within .002
    The inspection report that comes in the door of the machine, says it had .0002 at 4 postions 90 degrees apart. Thats what I want everytime. 26 other rotarys of 4 differant makes in this shop can do it!
    Jan 2007
    26
    DRD
    I also cnc port, I have a fadal with nikkens rotarys and have not had that problem. Do you use mastercam for porting. Been wondering how well it works, I think I would like that mastercam will let you ramp the paths where they meet from both sides, least thats what it looked like it would do.
    Nov 2007
    479
    Have you tried the reps recommendations?
    Jan 2007
    26
    Quote Originally Posted by djr76 View Post
    Rep is here doing it himself.
    4826
    At what circumference are you expecting to hold this tolerance? Is the minimum arc command still .001 degree on this table/machine combo?
    It might have backlash, but I'd be surprised at a lack of repeatability, if the tests are made all from the same direction of rotation. The thrust bearings on the wormshaft may not be properly preloaded? I don't know how you'd test for that, but you'd need super precision bearings and very careful testing and assembly to make it right. One cannot assume that an assembly error of some sort could never happen. It is a matter of determining the source of the error, more than looking at some sort of chart of specifications, to see if any improvement is possible.
    Jun 2007
    103
    Isn't this what backlash compensation is for?
    If the machine will repeat position, and the amount of slop is always the same, then there is a parameter made specifically to correct the problem.
    Feb 2007
    381
    Yes, yes! At what distance from center of the rotary are you trying to hold the tolerances? The farther away from the center line of any rotary, the farther off it will be, if it is going to be off. As stated above, over the course of 28" of travel, you could possibly be off about 0.004", not including the repeatability tolerance.
    My second question for you...Does that machine have a "brake" for the 4th axis? If it does, are you using it? If you don't, the backlash could allow it to move. Dumb question, I know...I just had to ask.
    Good luck.
    Mike
    Jan 2007
    26
    Well it wont repeat even in the same direction. The tech seen that last night. Then it wont repeat everytime, cant make it do the same thing everytime right or wrong even moving the same direction. It has a auto brake that ingages when the rotary stops moving.
    Nov 2005
    28
    Quote Originally Posted by Machineit View Post
    Mike
    Glad to see somebody pointing out the issues with manufactured goods!. After all I am a consumer also, I wouldn't put that money out for that kind of product or service.
    Jun 2007
    46
    G60?
    Maechler,
    Have you tried using G60 before your 4th axis moves. We have a 3YT with a TR110 trunnion which had issues on repeatability to my satisfaction. Haas tech came in and said the trunion was within tolerance. He suggested that we use the G60 command before our 4th and 5th axis moves. We changed our CAM post to accomodate this and I am impressed with the accuracy and repeatability. Hope the situation works out for you. Good Luck.
    GC
    Jan 2007
    26
    I looked in the manual for the g60 after reading your post, it said that it was for older versions of software. Guessing Haas includes that with the newer versions
    Jun 2007
    46
    I do not think its included with the newer version. We had to modify our postprocesser. The G60 should work with any Haas machine old or new. BTW, we have older controller and a newer one.:cheers:
    GC
    Mar 2010
    1852
    So, what happened? Is it fixed, did you throw it out the back door or what?
    May 2007
    74
    I have three Haas machines, two of them with trunnions TR160 and TR210. I would never count on them to be super accurate. They are affordable because they are decent machines, not fantastic.
  1. Replies: 4
    Last Post: 06-28-2013, 02:00 PM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
