586,133 active members*
3,687 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Stepper motors or ac servo motors?
Results 1 to 8 of 8
    Jun 2011
    What is the best for doing 3d carving. Will they both work.
    Jun 2010
    463
    Stepper motor or ac servo motors
    Both will work, it comes down to speed. Servo mtr are much faster but they are much more expensive also. So there is going to be a trade off of speed and expense, with the speed you may be able to add enough projects to offset that added expense for the servo choice.
    Nov 2007
    2466
    i have been carving large 3d with steppers on my camaster for three years, works well tuned right. that said going to servos on my new machine
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Jun 2011
    What do you mean by tuned right?
    Nov 2007
    2466
    by tuned i mean the relationship between gearing, power needs, drive and the balance of this when compared to what the end user needs in order to achieve thier desired work. a large motor with a too small drive will loose steps.
    "Tuned" is probably not the right term to use.
    As long as you don't exceed their capabilities (acclerating too quickly, or trying to run too fast), steppers work very well.
    24221
    Nov 2007
    2466
    maybe "configuration" might be a better word
  1. Stepper motors or servo required?
    By vwdevotee in forum Stepper Motors / Drives
    Last Post: 06-21-2010, 09:39 PM
  2. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  3. stepper motors or servo motors?
    By jprobst in forum Torchmate
    Last Post: 07-13-2007, 11:37 PM
  4. servo/stepper motors
    By hbui3077 in forum CNC Machine Related Electronics
    Last Post: 03-19-2005, 06:27 AM
