586,682 active members*
2,388 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > What do you think of the New Tormack PCNC-1100
Page 1 of 5 123
Results 1 to 20 of 88
    Nov 2004
    284
    Hi Guys
    I have been looking over the new Tormack CNC mill and it looks like a nice machine. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7540244496 I am not sure about the stepper motors instead of servos but I guess this is a cheaper way to go? Interested to hear your comments on this new cnc machine.
    Regards
    Bill
    Jun 2003
    1365
    Theres a lot that can be said about this machine, some positive, some negetive. Overall I think its pretty cool someone finally made a small but big enough machine for a good price. As many people know the dispute apon the drives, thats the negetive. Im sure if that argument gets started again this thread will be shut down.
    I am curious to see how the tool changing works, it appears that it has to do with some kind of drawbar grabber and how from there I dont know for sure.
    As for the steppers vs servos, servos are a little more complex to set up, and I am sure it has to do with the drive issue too. I am supprised to see it only being able to move 60ipm. I would like to see a machine like that doing 200ipm.
    Jon
    Nov 2004
    284
    Tool Change on the PCNC-1100
    Hi Jon
    Yes I also thought that the 60 ipm was disappointing. I don't know why this set up would not produce a higher number? I have seen other stepper systems move allot faster.
    As for changing tools, this is how I believe it is done. You open the spindle drive cover and on the left hand side of the spindle is a lever called the "spindle locking fork". The end of this fork is like an open end wrench that engages a set of flats on the end of the spindle shaft to prevent the spindle from turning. Using an ordinary wrench, you loosen the draw bar and change your tool holder. After re-tightening the draw bar, you swing the locking fork back out of the way and close the cover. The locking fork has a spring to keep it parked in the open position.
    The locking fork could be a problem if you forget to remove it before turning on the spindle motor? The spindle cover has a safety switch to prevent the spindle motor from being accidentally turned on when the cover is open. Maybe the locking lever should also have a safety switch on it?
    In regards to the drive dispute, they would have been better to use something different. I think this issue is going to hurt the sales of this product.
    I do like the idea of using good ball screws. I would like to see linear rails in a machine like this. That would really allow for faster travels. I guess it all adds to the cost.
    It will be interesting to hear from the first few guys that take the plunge to get an idea how they work.
    Thanks for your comments.
    Regards
    Bill
    Jun 2003
    1365
    Willy, I was under the impression that that spindle lock would actualy lock the drawbar and allow some other form of tightening(turning the spindle?) to tighten and loosen. About the speeds, on my (much smaller) mill I can reach 210ipm even though that mill has larger castings, I bet with my motors that mill could move at least 120ipm.
    It sure would be nice to see higher speeds in that, its not fun to watch a machine rapid, it should just be there when you blink your eyes
    Jon
    Nov 2004
    284
    Hi Jon
    No, the spindle lock lever grabs two flats on the top of the spindle shaft and you use a 13mm wrench to loosen the square end of the draw bar one turn to remove the tool holder. Of coarse they are suggesting that you would be using the "Tormach" Tool System with the Mill which I think is a great way to go on any Mill. They make it really easy to look after tool offsets on a CNC Milling Machine.
    Actually you could easily install an air cylinder on this Mill to make tool changing allot easier. Modify the draw bar so that it is longer and would accommodate a stack of spring washers under it to keep your tool holder tight in the spindle. Install an air cylinder over top of the spindle that you could activate with a push button. The air cylinder would push down on the top of the draw bar when you wanted to change the tooling. I think this could be easily added to this machine with out to much trouble. It would do away with the locking arm and wrench and you could change tooling with out opening the spindle drive cover.
    Take care.
    Bill
    Jun 2003
    1365
    Bill, I have actually started doing exactly that(with the air cylinder and all) but at this point I have been using a large lever. It will take a pretty decent sized air cylinder to get the pressure needed(need around 600lbs of pressure on the drawbar for only decent holding).
    I think the way they have it is too much work, it appears that you have to open the casing to change tools and all.
    Jon
    Nov 2004
    284
    Tool & Speed Change.
    Hi Jon
    To change tools or the spindle speed on this machine you must first open the spindle drive cover which requires loosening a small knob on the right hand side of the cover and swinging it open. They say 20 seconds for a tool change and 25 for a ratio change. Doesn’t sound all that bad.
    You would be better off using your air cylinder to release the tool rather than holding it in the spindle. To use a cylinder to release the tool holder, you would need to lengthen your draw bar and make room for a stack of spring washers under the head of the draw bar and the top of the spindle. These washers are what actually pulls the collect up into the spindle and puts the pressure onto the tool holder, keeping it from slipping in the spindle. The air cylinder is mounted above the spindle with it's shaft approximately 1/8" away from the top of the draw bar. When you want to make a tool change, you put air to the cylinder and it's shaft moves down against the end of the draw bar and compresses the stack of spring washers releasing your tool. Once you have the tool changed you remove air pressure and the cylinder rises allowing the spring washers to return pressure back onto your tool holder. To control your cylinder, you could use a air push button mounted on the side of your spindle cover. Or an electric solenoid controlling the air with an electric push button.
    The problem with using an air cylinder to hold your tool in the spindle is that you are putting this extra 700 or 800 lbs of pressure on your spindle bearings. With this other method the pressure is only on the spindle bearings during a tool change when the machine is stopped.
    If your spring stack had a pressure of 700 lbs. you could get away with a 3" cylinder at 100 psi to release your tool.
    The above method of tool retention with the spring washers is used on 85% of commercial milling machines. They use different tool holders that have a groove around them that small ball go into to grab the holder and pull it up inside the spindle. Neat idea and it works very well.
    Take care.
    Bill
    Jun 2003
    1365
    I have tried the method you are mentioning on my mill with my tormach tooling, and so far it works. now that I am thinking about it, I am getting a little worried about the stresses on my spindle bearings. I wonder if its an issue?
    the only thing I did different is used a lever and my bodyweight to release the tool.
    I have started to work on some custom tooling that uses retention nobs, I have a few holes to drill then I am ready to test it out, but that will be a while as I am at college now and probably wont get home till thanksgiving.
    Jon
    Nov 2004
    284
    Jon
    Would like to see your new tooling idea when you get it finished. Post some pictures sometime.
    Bill
    May 2005
    39
    The PC, Stand and the Rotary Table are Not included. It say's so in the description I don't why it's in the picture. At first look I thought it was, till I read on.
    Dec 2004
    524
    Instead of using an air cylinder, could you just put a block of steel with an adjustable bolt above the drawbar? Set your system up so that the zero on the z axis is offset. Now, when you move the z axis all the way to the top, the bolt will press on the top of the drawbar, compressing the spring and releasing the tool. You would have to give up a small amount of travel in the z direction, but you would get a simple way of releasing a tool.
    You might want to have an extra limit switch that stops the motor rotation. It would be bad news if a gcode bug could cause the tool to release.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Nov 2004
    284
    Hi Ken
    That would put allot of load on your ballscrew and stepper motor. You would need to push very hard to compress the spring washers to release the tool holder. The air cylinder set up would not put any pressure on the ballscrew or stepper motor. It would only be pushing on the one set of spindle bearings and this is when the spindle is stopped. I don't think it would be hard on the spindle bearings in this application.
    Take care.
    Bill
    Aug 2005
    49
    Hi guys,
    I noted a few questions that don't seem fully answered above.
    Spindle lock is similar to that described by someone else. Somewhat like a wrench on a pivot that can swivel into place. It works great. There are two interlocks in the design: First there is a bumper that will not allow the cover to be closed if the spindle lock is in place. The door simply will not close. Second, there is a microswitch on the door cover. The spindle will not start until the door is closed.
    Regarding the speeds: The machine is designed for short run and prototyping. Long production runs require high speed rapids, but when considering all the time taken by design, setup, and fixture building, the overall time from idea to delivered part is still hours. A difference of 65 IPM versus 200 IPM means very little. During our extensive testing the machine worked fine at 95 IPM, but taking steppers out to their limits is one of the things that has given them a bad name. We cut the speed limit back to 65 IPM to make sure that we never come anywhere close to missing steps. This is a very conservative design.
    Another reason for slower speeds is that it's an open frame design, like a toolroom mill. Very high speed rapids are fine for a fully enclosed VMC, but open frame machines have lots of pinch points. It's actually dangerous. Fine if you cook up your own machine, but questionable if you're making a commercial product.
    I have had quite a lot of experience with servos. AC servos are nice solid devices, but I have reservations about putting brush servos on a product. There are reasons that none of the mainstream CNC manufacturers use them (Haas et al). Again, fine for a homebuilt product, but a commercial product is a different beast.
    Some people here might be interested in the 13 page engineering overview I have posted. It covers a bit of the engineering behind the PCNC 1100. It's on the bottom of the list on our documents page at http://www.tormach.com/documents.html.
    One of the pre-production machines is now back on Ebay and there are still machines available for October/November delivery. I'll be happy to answer questions, but I don't stop by here too often. Feel free to contact me of the web site if you need immediate answers.
    Greg Jackson
    Tormach
    Quote Originally Posted by Willyb
    Just wanted to let you guys know that I'm hoping to be able to give you some first hand info on the machine very soon. It'll be a pretty big jump from my current Taig CNC mill so I'm sure I'll be impressed. I've had my order in for a while now and am keeping my fingers crossed for a delivery sometime this month.
    Dave.
    May 2004
    290
    Quote Originally Posted by JFettig
    Jon
    Jon et al,
    Please forgive my ignorance... what is the issue with the drives? Are you refering to the fact they are using steppers instead of servos? Or do you have issues with the controller they are using?
    Carlo
    Quote Originally Posted by cbass
    Jon et al,
    Carlo
    Carlo,
    It's probably better not to go into here (so this thread doesn't get closed down,) but just do a search for Tormach here and you'll find what the issue is...
    Note: It's more a legal/ethical issue than a technical one...
    May 2004
    290
    Gotcha,
    Thanks!
    (spoken in a whispered tone)
    Nov 2004
    284
    Anyone Have a PCNC-1100 Yet?
    Interested to hear of anyone who has purchased one of these PCNC-1100 CNC Machines. It would be nice to get an opinion and talk to someone who is an owner of one of these machines and actually used one. Thanks.
    Regards
    Willyb
    Regards
    Willyb
    As far as I understand it, this is the first shipment. The only way to have one by now is to have purchased one of the pre-production machines...
    I wasn't expecting it till the middle of November, but it looks like it may make it here earlier. I need to get moving on constructing the stand for the machine. I'm using Tormach's plans for 2x4 and plywood construction. Hopefully it will hold up ok to flood coolant...
    BTW, they just put up A LOT more info on their website.
    Dave.
    259
    I can't truthfully comment on owning one of these but I did install one here in the UK back in the end of July or begining of August.
    No connection with Tormach, this was a paying rigging job.
    I was very impressed on the size, weight and build quality.
    It was obvious from the start that this was a 'as built CNC' and not a conversion of a manual machine.
    My brief was to get this into place and leave the new owner to connect the computer and get it running.
    As I said earlier I was that impressed that I called back a couple of weeks later when I was in the area to see this machine under power.
    It was behaving flawlessly and nothing I saw gave me cause for concern.
    The machine uses Mach3 as a controller and the new owner who may chime in here as I know he read CNCZone, had fitted a touch screen with an overlay keyboard on it making a very neat self contained machine.
    It looks to me that a lot of thought has gone into this as I can't see any cost cutting on the spec.
    Two area's that could be pared down to save money are the breakout board and pressure oiling which many conversions don't have.
    Because this seems to be a genuine attemp at a reasonable cost genuine CNC mill both are fitted.
    As said previously I have no connection with Tormach and was paid by the owner of the machine and not Tormach for my work.
    John Stevenson.
    Nottingham, England.
Page 1 of 5 123
