587,004 active members*
2,760 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cambam issue or Mach 3 Issue??
Results 1 to 12 of 12
    Aug 2010
    I have been lurking for quite some time because it took me over a year to build my CNC router and for the past month I have been learning the basics of CamBam 9.8 and the most recent version of Mach3.
    I designed a pocket 2.5" X 2.5" X .5" deep in CamBam. Because I am a newbie, I took a pencil and marked the center of my work piece. I zeroed my machine using the mark on the work piece as a reference point, I loaded the g-code that I created from CamBam into Mach 3 and ran the file. The machine runs great with no problems except instead of machining a pocket dead center of my work piece 2.5" X 2.5" X .5" deep, it machines a pocket nearly less than half the size, half the depth and off center. If I remember correctly the edge of the small pocket is right on the center mark.
    I have double checked all of my settings and I have machined about a dozen or so pieces of MDF and now I am a little flustered and need some advice from the Pro's.
    Thanks in advance
    Sounds like you need to set the origin in CamBam to the center of your pocket.
    Also, is Mach3 set up correctly, so that when you tell it to move 1", it actually moves 1"? If so, then the problem is most likely CamBam. Can you post the code?
    Aug 2010
    Thank you for your help
    I have attached the Cambam file as well as the g-code that I created. This is a good place to start. It might be how I configured Mach3.
    Attached Files Attached Files
    The g-code says it's for a .125" tool? If so, the pocket will only be 2.25".
    The g-code has the toolpaths at 2.125. Add the radius twice, and you get 2.25"
    It's centered on the Y axis, but 1/16" left on the X axis. X min = -1.125, X max = 1.
    So, if it's the wrong size, then you probably have your steps/unit in motor tuning wrong. Just make sure you don't have any axis scaling enabled.
    Not sure on the off center part. Get it the right size first, then we'll go from there.
    Aug 2010
    I made a couple minor changes
    Yep, the dimensions were off just a little so I made those changes. I think the majority of my issues are with how mach 3 is set up. I don't have any instructions on how to set it up. I tried tuning the motors manually, but without having the right information it is difficult so I just guess. I also tried to tune motors with the auto feature. I would tell it to move one inch and it would only move 1/8" so I would enter that data and then my motors would squeal and not turn. I am to the point of pulling my hair out. My y motor is a nema 23 300 oz/in y axis is a 3/8 - 16, x motor is a nema 34 640 oz/in x axis is a 1/2 - 10. Also have xl timing pulleys on both the motors and leadscrews they are all the same diameter with 24 teeth. I am a little frustrated because I do not know how to calculate this stuff to make the machine run the way that it should.
    Aug 2010
    You were absolutely correct
    You mentioned something about motor tuning so I did some searching and found a good Mach3 instruction manual and read every single page until I understood somewhat of how to tune the motors. What had happened was I had set the "steps per" way too low and set the "velocity" and "acceleration" way too high. it took a few tries but I finally nailed the problem that I was having. I wanted to be sure so I ran a test and machined the clock pocket that I had designed and it turned out great. Thank you so much for making a comment that got me thinking about finding a solution.
    Jul 2007
    1602
    This might be a good start. It will help you get your steps per inch right:
    [nomedia="http://www.youtube.com/watch?v=XkO5tc-jSxw"]YouTube - ‪Improved Mach 3 Axis Calibration‬‏[/nomedia]
    bob
    Aug 2010
    Angry I need some advice
    My wife asked me to make her a key chain with her name on so I created a key chain project in CamBam, created the g-code and proceeded to make the key chain. Half way through I noticed that my machine was running awesome but it was machining a mirror image of what I had designed. Any ideas as to what would cause that to happen?
    :drowning:
    Feb 2005
    521
    Quote Originally Posted by tracyranson View Post
    :drowning:
    In your Mach3 motor pin settings, you need to invert your X direction pin (or not invert it if it is currently inverted).
    Either that, or check you haven't accidently set a -1 scale on the X axis (this is displayed next to the Mach3 DROS).
    www.cambam.co.uk
    Or, just check the "Reverse" column for the X axis in Config > Homing/Limits.
    You're X axis is running in the wrong direction.
    Aug 2010
    Talking
    Quote Originally Posted by 10bulls View Post
    Is it possible for the same thing to happen if I have the A+, A- wires swapped with the B+, B- wires.
    Feb 2005
    521
    Swapping just one pair of stepper wires will also reverse the direction
    For example:
    B+ -> B- and
    B- -> B+
    ...but changing it in Mach is just as good.
    www.cambam.co.uk
  1. Mach 3 scaling issue? not sure if its machine.
    By CNCwilson in forum Mach Software (ArtSoft software)
    Last Post: 07-12-2010, 08:51 PM
  2. Mach 3 homing issue.
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 07-10-2010, 03:04 PM
  3. MACH 3 FREEZE ISSUE XP pro 02
    By carbidecraters in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2010, 07:49 PM
  4. Mach issue with my mill
    By Rich05 in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2008, 12:00 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
