586,961 active members*
2,929 visitors online*
Results 1 to 20 of 26
Hybrid View
    Oct 2008
    248
    Another cnc plasma/router build
    Hi everyone I havent posted in a while. I've been working on a few things. First thing i started was a cnc plasma/router. Second thing working on becoming a new daddy again, it was a surprise but its cool. I need to get my machine done ASAP if you know what I mean. Heres a few pictures of where i am on my frist idem, You all know whats involved in the second idem lol :-). The piece of MDF you see holding the rails will be a 1/2" X 4" x 48" piece of aluminum. I was going to use either timing belt or roller chain, or maybe use ballscrews. I hope you like what I got so far. Let me know what you think.
    Attached Thumbnails Attached Thumbnails cnc plasma machine 002.jpg   cnc plasma machine 003.jpg   cnc plasma machine 005.jpg
    Feb 2009
    227
    Good Start...
    Hey Mike,
    Looks like your off to a good start nice rails and side plates you have there. As for a belt drive on a router table thats a big no no :nono: When the router bit bites into the wood it wants to go any direction but the way you want it too, just like a hurricane. The bit will grab the wood and stretch out the belt and you will get poor cut quality. You may be able to use a double or triple belt drive to avoid this stretch problem. Its not a problem with plasma because there is no cut force on the z head... I would recommend ballscrew or R&P....
    Oct 2008
    248
    Thanks for the heads up regarding belt drive in a router setup. Thats what I was thinking also I figure belt wouldnt be good enough if set up as a router. I was more or less thinking that setup for the plasma only. I have a lot of parts to make now and the belt opions would be the less $$$$ to get this up and running. Thanks again for your thoughts.
    Oct 2008
    248
    Wow only 1 reply, and over 200 plus views. I guess i'm doing a good job
    Oct 2008
    95
    Hi Mike. all I know is what I have learned from the posts here. Most say that the ball screws are not fast enough to make changes of direction on thin material. Most of the builds for plasma use rack and pinion drive, and you can use a 3:1 belt reduction to aid in torque which enhances your acceleration.
    I like your table, I wish I had gone with the 80/20 stuff instead of steel. You may want to check out www.precision plasma.com and Tulsa Turbo from this forum. A build by
    Winegar is also a good read......good luck
    Oct 2008
    248
    I have a little update, the machine has motion. Here's a little video of it moving around. Click link below. I ended up going with a roller chain, and you know it seems to work very well. Check it out.
    YouTube - Broadcast Yourself.
    Sep 2011
    My apologies if I am jumping in at the wrong spot, just joined this form and still not sure how to navigate. Seems that there is a wealth of knowledge on the board, I am looking for a CNC plasma table for our manufacturing class, any suggestions or comments would be appreciated. Thanks.
    Oct 2008
    248
    Hi, it would depend on what the budget would be for a Cnc plasma cutter.
    Mike
    Quote Originally Posted by chris.code View Post
    Sep 2011
    Hi Mike, I have looked at one from FastCut and another from Torchmate (now owned by Lincoln) we need one that is strudy, students are very hard on equipment. Unfortunately these will not come cheap, the biggest one that will fit in the shop would be 4x4. As for $$$ I will have to come up with a number and talk really nice to administration. Cheers, Chris
    Oct 2008
    248
    Update: I have hooked up the relay for torch on/off and i have a video on youtube, do a search for mike2768 and check it out. it's just a short video of my machine cutting a small bracket. I'm very happy with the machine and how the roller chain works. I see no problem using roller chain, it seems good for what i can tell. Anyways check the video out.
    Sep 2011
    Video
    NICE, the cut quality looks good.
    Feb 2007
    58
    Re: Another cnc plasma/router build
    Heya Mike, looked up the youtube videos. great job on the plasma table! How did you hook up the relay to start the arc on the lotos?
    Want to make a pantograph tracer setup with a foot pedal to start/stop it.
    Oct 2008
    248
    I hooked the relay to the coolant input and edited my programs to start and stop the torch by including and coolant on and off command
    Feb 2007
    58
    ok great thanks, I will see if I can find matching plugs to put inline so I dont have to cut anything
    Feb 2007
    58
    what were the connections on the plasma cutter side of the equation? i have a lotos ltp500d with pilot arc. it says cnc ready, but I am not sure how to rig it up to an external relay or switch.
    Oct 2008
    248
    The way I did it was, I just taped into the two wires that go to the trigger/on & off switch.
    Oct 2008
    248
    Ya I was going to do the same, but the Lottos dealer where I got my plasma from never got back to me regarding the plug
    Feb 2007
    58
    after spending half a day reading through spec sheets and doing searches, I ended up finding a compatible set of plugs for the lotos ltp500d torch. CNX-505, and CNX-510 are the vendor order numbers (not mfg part numbers)
    Electric Scooter Battery Charger Connectors - ElectricScooterParts.com
    these were the best match I could find but were generic with no spec sheet looked right so bought them on a hope. it was like 11 bucks for the pair delivered, they accepted paypal.
    got them today and glad to say they fit !
    edit --
    actually after taking the gun apart, looks like you only need the female plug. I was thinking it required a pass through connection with only one wire switched to complete a connection to the torch end. In the handle though the wires just connected directly to one another through the switch.
    Oct 2008
    248
    I'm glad you found some plugs, they will a cleaner setup
    Sep 2014
    14
    Hey guys, I've been doing a bit of research and am a bit bored so want to try out building a plasma table so I can start tinkering at home. I'm interested in your build mike.
    Where did you get your plans from?
    In Aus the rack and pinions are very expensive so I was looking for alternatives in timing belts and chain drives.
    You say your chain drive works well I'd be interested in how it's working.
    Cheers KD
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. 4 x 4 Plasma/Router Build
    By sodfarmer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-23-2009, 10:51 PM
  3. Plasma/Laser cut parts to build a CNC Router
    By NEATman in forum DIY CNC Router Table Machines
    Last Post: 01-26-2007, 11:29 PM
  4. 1st build: Router/Plasma
    By krebsatm02 in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 03:56 PM
