587,033 active members*
3,342 visitors online*
Thread: R&P Mystery
Results 1 to 13 of 13
    Jan 2007
    211
    R&P Mystery
    Before I get into this, I want to make it VERY CLEAR that I really like the CNC Router Parts Rack and Pinion drives. What follows has me a baffled.
    I do a lot of 3D sculpting type work that runs for hours. It is the type of work that steps over about .006-.007 in one axis and then cuts in the other axis. (that was for those of you who do not do that type of work). Typically on my machine, I step the axis that has the dual motors. The feedrate is usually around 180-250 IPM. This particular problem is occuring at the 180 IPM setting.
    I was running along nicely when I heard the dreaded "Klunk", the sound of a tooth being skipped in the rack. Of course that was the end of that job.
    Started running tests. This happens about every 3 inches or so. I have checked my Mach3 settings to make sure I did not having anything really stupid, like unequal steps between the motors.
    Ran a test loop in which I caused the machine to run back and forth at feedrate 1000X. Never missed a tooth. Hmmmm.
    Set up another test so that it emulates my normal sculpting work, but is much shorter so I can test faster. Problem is back.
    Does not happen when I rapid.
    I am thinking this has something to do with Mach3 and not sending the same number of steps to each motor. It is the only thing I can think of at this point.
    The tension on the drives is set quite high. It takes a lot to force the pinion off the rack.
    Anyone have any suggestions? Remember, this ONLY happens when I step the dual axis repeatedly.
    Dec 2010
    you picking up some noise somewhere?
    Jan 2007
    211
    The following was NOT accurate, after further testing, I discovered the problem had just changed in the sense that the skips are now farther apart.
    I may have solved the issue.
    The kernel speed was set to 45K in Mach3. Ran the speed test, and it was fine. But I went ahead and dropped the kernel speed back to 35K anyhow and repeated my test pattern.
    Problem did not repeat during three test runs.
    I was not using those 1000 IPM rapids anyhow, had them set to 600 IPM.
    My guess is that my computer is not quite capable of handling the 45K speed, even though the Mach3 test says it is ok.
    Apr 2007
    8082
    I nearly lost all of my marbles working on a problem just like this a year or so ago. In my case it was in Mach3 Config/Output pins settings. Outputs #2 through #6 were disabled and outputs #7 and #8 were enabled. Changing Outputs #7 and #8 to disabled fixed the problem. The DIR signal to the A axis motor was not the same voltage level as the DIR signal going to the X axis. It was 0.67vdc instead of 4.85vdc as it was for the X axis motor. Be sure to save the configuration changes you make and exit/restart Mach3 for the changes to be implemented.
    This was causing racking to the point that the pinion gear would climb up on the rack teeth and then a loud snap was heard as it jumped over the rack teeth under heavy spring loading.
    See post #1924 in "CarveOne's Work Table CNC Router Build" and previous posts there for some details.
    Mariss Fremaniss was key to my finding the settings error by having me look at the DIR voltage levels with a DMM.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jan 2007
    211
    CarveOne:
    Thanks for the reply. I tripled checked those settings. They are and have been disabled. I was hoping I was going to get off easy and benefit from your experience. No such luck.
    I did read through the post you referenced. At least it is a place to start!
    One thing is REALLY bothering me. . . I cut a much larger project yesterday and did not see any evidence of this problem. I did not mess around with anything in Mach3, change anything with the wiring or mechanically on the machine.
    Another thing that bothers me is that this problem only happens when I am making those very small repetitive moves. I can run the back and forth motion test 1000X without losing any steps or jumping a tooth.
    Apr 2007
    8082
    Quote Originally Posted by Treischl View Post
    CarveOne:
    If you can get to the Step and DIR signals follow the suggestions by Mariss in my build log as to checking the signal voltages to be sure they exceed the logic low and logic high minimum levels. Some parallel ports and parallel port cards don't supply the correct voltage pulses. A marginal pulse level or too narrow pulse shape will give erratic results in the pulse counts that each motor gets. I was seeing it in multiple stepdown levels but not on a one pass full depth cut. I was seeing stair steps on two adjacent sides of a square pocket while the other two sides have a straight wall.
    Your symptoms sound like one motor is not getting the same number of valid pulses at both motors. It causes one motor to get ahead or behind the other.
    If you have a break out board between the computer and your motors it could be correct levels at the input of the board and incorrect at the outputs going to the motors. I have G203V drivers and a C11G board. If using a G540 you have a little different situation with getting access to the wires. For the DIR signal the voltage level goes high when running in one direction and a low level when running in the other direction.
    CarveOne
    CarveOne
    Jan 2007
    211
    Carve:
    Yes, the G540 is a little different. Not sure how I am going to get at the signals? First I would have to figure out which pins are which in the DB9.
    About the only things I can think of at this point is to try a different parallel cable from the computer to the G540 and if that does not work, send the G540 back to Gecko to have it checked out.
    This is one ugly problem!
    35538
    If you have a G540, try increasing the pulse widths in motor tuning to 15 or so. The G540 seems to be very sensitive to marginal ports.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2008
    1166
    I had a similar problem with my G540 and a crap parallel port. I would not get motion on my Z motor during very slow moves. Typically I'd make a move with lots of movement in X and Y but very minimal Z movement, so it might move 0.25" while the X and Y both went 48" or something like that. And the Z would sometimes not move. I tracked it down to low voltage levels from my parallel port, just like Carveone. I used an oscilloscope to do this. You have to load the port with either the G540 or resistors that draw similar current when you do this or the voltages will look fine. I installed a breakout board parallel port and found that a few of the pins on that weren't up to snuff either. So I ended up using dual break out ports and custom wiring a cable that used pins from both ports to drive the G540. Works great now. I have some posts in the Gecko forum where I show scope shots of what the step pulses looked like. I don't know how it was working at all.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
  1. Mystery
    By SteveY in forum Solidworks
    Last Post: 10-25-2010, 05:50 AM
  2. DYNAPATH MYSTERY!!!
    By Osunator in forum G-Code Programing
    Last Post: 05-04-2010, 10:26 PM
  3. mystery function in v23
    By MSPP in forum BobCad-Cam
    Last Post: 03-13-2009, 06:37 PM
  4. mystery self feeding
    By keen in forum Mach Mill
    Last Post: 02-25-2008, 08:55 PM
  5. Mystery drill
    By Vern Smith in forum Haas Mills
    Last Post: 04-21-2007, 09:15 PM
