Graphicman
That makes better sense, that the relay is just a switch, & does not have any voltage on it, you can wire it to the VFD from the photo in the other post, this will only turn the VFD on it will not control the speed, the spindle will run at it's max speed 24,000 , if you have the parameters set correct
