586,308 active members*
3,430 visitors online*
Thread: Ghost image
    Jul 2006
    83
    Ghost image
    I'm cutting .25 acrylic and getting this "ghost image" on the side of the table diagonally opposite to mirror 2, It does not affect the cut, but the ghost is just powerful enough to brown an image on the paper. I had this happen once when the cone was not seated properly, but it was anywhere on the table. Cone is fine, and no problems anywhere else on the table. Thanks Neville & God Bless the troops, past & present on this Memorial Day
    Jun 2009
    146
    Check where the beam is hitting the last mirror on the laser head . plus where it hits the lens.
    You are getting a reflection somewhere which is causing the double image. Probably its not hitting the lens correctly.
    rabbit / ls3040
    Dec 2008
    1258
    Hey Neville,
    As geekinesis suggested it is likely due to alignment, resulting in the beam reflecting and creating your ghost but if alignment is good I would check that the lens isn't cracked.
    Zax.
    Jul 2006
    83
    Wouldnt a cracked lens exhibit itself everywhere though? I was cutting 6 parts out of a 36x24 sheet at a time. Only the one closest to the control panel had the ghost. I shall do some test cuts and see what might be going on. tx all. N
    Jun 2009
    146
    If the beam is at even a degree off horizontal then it will be hitting different parts of the lens at different points on the table so it could either be hitting a small crack on the edge of the lens or even a scratch on the lens would affect the beam. The lens is very soft and brittle so easily damaged.
    Try just realigning the mirrors and checking the beam is exactly horizontal and that will probably solve the problem.
    rabbit / ls3040
    Sep 2010
    12
    Dubliner,
    I had the same problem on my Vytek. It's all in the alignment and the point where the beam passes through the nozzle below the focus lens. The beam (on mine) was grazing the nozzle and reflecting off. It takes a VERY in-depth alignment procedure to correct this. Take your time, bring a lunch.
    Wish I'd bought a Multicam.
  1. Ghost Image explorer
    By M.RISHIKESH in forum Computers / Desktops / Networking
    Last Post: 10-08-2010, 12:59 AM
  2. M500 Redsail Ghost Image
    By reneisla in forum Engraving Machines
    Last Post: 12-15-2008, 04:59 AM
  3. Dual Image (ghost) on final product
    By reneisla in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-27-2008, 02:26 PM
  4. Ghost HD backup
    By OLD_Newbie in forum CNC Machine Related Electronics
    Last Post: 06-09-2007, 01:28 PM
  5. ghost is here
    By nerginer in forum Waterjet General Topics
    Last Post: 02-18-2007, 06:19 PM
